First post, by UK_John
had to start a new thread as moderator closed the Battlespire problem thread, so here is a new one....
I get good framerates, the intro plays fine, all in DOSBox 0.73, I can hear the creatures when they hit each other and when they cry out out, but I get no speech when I go into dialogue and I have never heard music.
I mount c c:\batspire and d m:\ -t cdrom for the videos and waves.bsa, I get the intro movie which is pulled off the CD, but obviously waves.bsa isn't being accessed properly! Anyone had this problem with this or any other DOS game? I have tried copying the videos folder and waves.bsa to my c:\batspire folder, pointing to it with my cd mount, but it's still the same! Should I extract the files from the bsa or something?
Any help would be greatly appreciated! 😀
Reply 1 of 4, by HunterZ
Not sure about speech, but the music at least is supposed to be on audio tracks on the CD.
Reply 2 of 4, by UK_John
Well, I mounted the cd and got the intro movie. I suppose the waves.bsa is the speech then,never had a problem with DOSBox not reading music tracks off CD before! Obviously reading the disk for other things!
So if you're right, I am even more confused!
Reply 3 of 4, by HunterZ
Maybe you need to add additional parameters to the mouse, like -ioctl or -usecd 0, or maybe your CD doesn't have the audio tracks, or maybe your computer doesn't play audio tracks correctly, or...
I ended up making a BIN/CUE rip of the CD and imgmount'ing it so that DOSBox could handle the CD audio internally. Helps a lot with responsiveness since the game grinds to a halt when it needs to switch from music mode to data mode.
Reply 4 of 4, by eL_PuSHeR
[MOVED]
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
