First post, by poao
I have an old DOS program that I need to run under Windows XP. I tried first to run the program using windows XP own command line (Run -> cmd) but the program did not run very well (worked partially). In Dosbox the program runs perfectly fine. The only problem left for me is to be able to print from DOSBOX.
I have read a fantastic tutorial about printing from DOS programs under windows xp (http://members.shaw.ca/bsanders/printfromdos.htm). After following the tutorial I am now able to print when I start the program from windows xp command line (but some parts of the program don't work while in dosbox the work fine). The problem is that this tutorial did not help me to print from Dosbox (it's just works when I print form windows command line - when the program is running from dosbox nothing is printed).
Is there any way to fix that ?
By the way, I also tried running dos2usb and it didn't help to get the program print when running from dosbox.
Thanks
Poao
