First post, by handsopen
Hello Everybody,
I have a DOS application that needs SHARE.EXE to run. Could you tell me how can I run share.exe?
I apreciate any help with this issue.
Thanks.
Luis Martínez
Reply 1 of 10, by MiniMax
Rank Moderator
Moderator
Type SHARE.EXE
_________________
Reply 2 of 10, by handsopen
Excuse me If I did not explained myself correctly. The DOS application works fine at Windows XP, but when I tried to run the app on Windows Vista I got the error message "...This system does not support fullscreen mode."
Then I downloaded and installed DOSBox, also I copied "share.exe" into my DOS app's folder. I have mounted the folder as c: drive and run the share.exe program (I did not get any share messages after run it).
Now, when I run my DOS apps. It still shows the message "You need to run share.exe"
It isn't no effect after run "share.exe".
Any ideas?
Reply 3 of 10, by Qbix
Rank DOSBox Author
DOSBox Author
use something else.
DOSBox is for games. hence no share support.
If you want to go the hard route, you can boot real version of MSDOS inside dosbox, however the procedure for that is similar and maybe even more complicated then using something like virtual PC
Water flows down the stream
Reply 4 of 10, by collector
Perhaps it looks in the autoexec.bat for a share entry instead of checking to see if it is loaded?
Reply 5 of 10, by wd
Rank DOSBox Author
DOSBox Author
No they look into some dos table chain for a byte to have a certain value,
but it doesn't really matter how they do it.
Reply 6 of 10, by DosFreak
If you want to run DOS apps in fullscreen in Windows Vista+ you'll need to install the Windows XP video drivers for your video card. That's not recommended but you can do so.
Make your games work offline
Reply 7 of 10, by handsopen
I appreciate your answers. I've been looking for another solution to run my DOS program instead of load and configure Windows XP Video Driver over Windows Vista. I found in DOSBox pretty good DOS commands emulation but it doesn't work for me. Simply I will delay the Windows Vista migration on those pc that run the dos apps. If I find the way to make it run I will let you know.
Reply 8 of 10, by adam.g
I think that previous version of DOS-BOX was working well with share. Now I cannot run Word 6 in Windows 3.11 because of this error. In prevoius version it was possible.
Reply 9 of 10, by wd
Rank DOSBox Author
DOSBox Author
This was a bug, more an unimplemented table that accidentally said
"share is enabled for this drive" where it wasn't. So even if the app
MAY look like it works, the results are arbitrary.
Reply 10 of 10, by Davros
in windows 98 (if you go that route with virtual pc)
you need share.exe in c:\windows\command
