wolf3d for mac
First post, by temptingthelure
Anyone know where to purchase wolf3d for the mac? I cant find the mac version anywhere. And is there a way to run it on modern non-mac systems? It only seems to work with system 7 or earlier.
Reply 5 of 31, by Sune Salminen
You can play Wolfenstein in DOSBOX. Not the Mac version but still.
http://boxer.washboardabs.net/
If it absolutely has to be the Mac version, you could try a Mac II version of MinivMac for OSX maybe.
If you want to run System 7 you could also try Sheepshaver, here's a tutorial:
http://db.tidbits.com/article/10679
Reply 7 of 31, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Supposedly yes, but the link to the site is down it seems http://basilisk.cebix.net/#download
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 9 of 31, by Targaff
temptingthelure wrote:
Yeah, but basilik can only emulate up to system 7, no more. What can someone with a modern system like OSX do to play wolf3d mac on it?
Basilisk runs up to 8.1.
Intel CC820 | PIII 667 | 2x128MB SDRAM | 3Dfx Voodoo 5 5500 @ Dell P790 | Creative SB PCI128 | Fujitsu MPC3064AT 6GB + QUANTUM FIREBALLlct10 10 GB | SAMSUNG DVD-ROM SD-608 | IOMEGA ZIP 100 | Realtek RTL8139C | Agere Win Modem
Reply 11 of 31, by Dominus
DOSBox Moderator
You can also try through DarwinPorts.
I know what you mean, but to not further confuse users, DarwinPorts is now called MacPorts (http://www.macports.org/) to distance themselves from the fraudulent darwinports com site, see http://trac.macports.org/wiki/DarwinPorts for details.
And yes, via MacPorts you can install basilisk II, I haven't tried to but it is in the ports list 😀
Reply 12 of 31, by Sune Salminen
Right, thanks.
And what collector said; installing and playing Wolfenstein 3D in DOSBox (with the Boxer front end) is about 1000% less complicated than getting a whole System 7 or 8 installation going in a Mac emulator. It wouldn't be worth the trouble just for one game IMO.
Reply 13 of 31, by temptingthelure
Ah yeah, that's right, but still its emulating an old mac system to play mac wolf3d.
Reply 14 of 31, by temptingthelure
collector wrote:
And is there any real advantage to the Mac version of Wolf 3D? I would imagine the the DOS version in DOSBox would be far less trouble.
Well, if you have played the mac version of wolf3d, it's very different from wolf3d. It looks different, and it has different weapons. It was not just a port of the dos wolf3d. I'd like to be able to play that mac version.
Reply 15 of 31, by Dominus
DOSBox Moderator
From what you can tell by that thread you should be able to play it by using basilisk II.
Reply 19 of 31, by wildweasel
http://wolf3d.darkbb.com/addons-mods-etc-f4/m … wnload-t850.htm - This'll work in Windows; it's a port of the Mac's "Wolfenstein 3D: Second Encounter" to the Windows-based SDL Wolfenstein port. If your OSX system has VMWare, Virtualbox, Parallels or similar, this might work for you.
Also, I haven't had much luck running Wolfenstein through Basilisk II - granted it was an older version of the emulator, and while the game did run, it would occasionally just crash the emulator. Maybe it's been fixed, but I haven't managed to get the newer Basilisk II's working on my Windows machine due to crazy conflicts with the version of GTK that came with Pidgin. =P
