Application can't find its CD
Reply 40 of 45, by ripsaw8080
Rank DOSBox Author
DOSBox Author
So, VPC does not extract the restricted filenames from the image as DOSBox does; I suspected as much. If you look at a directory of the image mounted in DOSBox, all the non-alpha characters are changed to underscores. That is an important difference between the two systems; but again, it's not the only issue, and can be gotten around with Daemon Tools or so.
The error message stating that the program should be launched from the CD can result from the failure of any one of a rather long list of checks that the app performs.
Reply 41 of 45, by gidierre
gidierre wrote:
would that explain why this virtual dos can do it right?
(sorry for double posting)
well apparently I can answer myself right away before falling asleep
it can't be so, since Win3.11, where aemn.exe just fails like dosbox and unlike dos 6.22, still seems to handle those **** non-alphanumeric characters right, so things will have to be more complicated:
and W31FW on the dos side of it:
We often forgive those who bore us, but we cannot forgive those whom we bore. (La Rochefoucauld)
Reply 42 of 45, by ripsaw8080
Rank DOSBox Author
DOSBox Author
How many times have I stated that the filenames are not the only issue!?
Anyway, going by the timestamps on the files, the app was last updated in 2000, possibly for compatibility with the NTVDM (where it does work)... wouldn't surprise me if they were not concerned about operability with Win3.x 😉
Reply 43 of 45, by ripsaw8080
Rank DOSBox Author
DOSBox Author
I made a couple of TSRs to get the app running in DOSBox. Run AEFIXIMG.COM when mounting the CD image, and AEFIX.COM when mounting otherwise. Both TSRs perform an adjustment of INT 21/AX=440E, but only for the D drive, so make sure to mount the CD there. The TSR for image mounts also applies restrictions to filenames coming from the app so they match what DOSBox uses. Source code is included in the archive.
Maybe it's of interest to the DOSBox devs: the app wants the "get logical drive map" function to return al=0 (one drive mapped) for a CD drive, but DOSBox is returning error code 1 (invalid function).
    AEFIX.ZIP
    1.94 KiB
    334 downloads
