Sound Blaster PCI128
First post, by sgt76
I have a PCI128 card (CT4700- the rebranded Ensoniq 1370/ 1371) and can't seem to find any Win 98 drivers that work. All I seem to be getting from Creative's site are some add-on useless registration crap files. Also from some googling it seems Creative doesn't list drivers for this card anymore- they only have non-Ensoniq PCI128 drivers.
Does anyone know where to get a driver for this? Any help would be much appreciated.
Reply 2 of 23, by sgt76
That was fast. Thanks! Will try them out and see if they work.
Reply 3 of 23, by ratfink
if you search the creative download section for es1371 you should find the drivers. I couldn't find anything earlier though, like sb16 and such.
Reply 4 of 23, by sgt76
I did go to the creative site and tried all possible drivers incl es1371. Didn't work though...maybe I'm doing something wrong?
SB16/32/64 and variants are not a prob as PNP drivers are already incl in win98se. That's my current onboard sound card (sb16 on a cu430hx).
Reply 6 of 23, by sgt76
hmphh. no luck at all... I think I'll get another card- something not by creative this time. maybe a c-media 8738.
Reply 7 of 23, by retro games 100
Have you tried driverguide.com? I just looked on that website for CT4700, and DL'd a package called SOUND_BLASTER_PCi_128_CT-4700. You might want to give that a try.
Reply 8 of 23, by sgt76
Thanks! Downloading now...
wish I'd known about that earlier, but I'm totally noobish about soundcards 🙁
Reply 9 of 23, by gerwin
Okay so some 128PCI cards, like yours, require another type of windows driver... now that is convenient.
Reply 10 of 23, by swaaye
Creative has a few old cards like this with hard to find drivers because they couldn't be bothered to put together an all inclusive package for every card revision.
Reply 11 of 23, by HunterZ
...which in turn is because most of those cards are simply relabeled cards made by companies that Creative bought out, with re-branded drivers...
Reply 12 of 23, by swaaye
Which of course is ridiculous because they produced products based on the tech for years. There are about 6 different sound cards and there are also motherboards with the chips.
Reply 13 of 23, by HunterZ
Can't remember what the model numbers were for my SB PCI128. I liked that it could do EAX and 4-speaker positional sound, but its DOS support and wavetable MIDI were pretty awful.
Reply 14 of 23, by sgt76
@ retrogames- I downloaded the entire install cd. The drivers sort of work in that there is now sound, but unfortunately that sound happens to be mixed with a lot of screeching/static. Maybe my card is shot?
This is turning out to be very time consuming. I'm inclined at this point to exchange this card for a c-media or anything non- Creative for that matter.
Reply 15 of 23, by retro games 100
I think this is a fairly common problem with early Creative PCI sound cards. Some things to consider -
-If you installed from a (downloaded) CD, then there's probably a downloadable driver update.
-There may be a resource problem. The IRQ assigned to the card may be inappropriate, or it may be better to put the card in another PCI slot. Edit: I think this problem can be caused by an AGP graphics card hogging the system's resources.
What are the PC components you're using? Also, it may be quicker to try another card - there's still quite a few win9x cards available cheaply on ebay.
Reply 16 of 23, by gerwin
Do yourself a favor and get a Vortex 2 soundcard. Or when DOS does not matter to you a Santa Cruz soundcard instead.
Reply 17 of 23, by sgt76
OK, here's the setup that I'm trying to use this card on:
Pentium 233MMX
Intel CU430HX motherboard - 2 PCI, 2 ISA slots
128mb ram
1x Voodoo 2
3com 905b ISA ethernet card
Win 98SE
So, no question of there being AGP related issues. And I've set IRQ assignment at automatic. Otherwise if left to manual, I got blue screens complaining that the IRQ assignments were off.
Thanks for the suggestions. I'll have to see what I can get my hands on. This time though, I'll make sure to go for something with (easily) available drivers
Reply 18 of 23, by HunterZ
Creative's PCI sound cards are notorious for screeching and popping, especially on VIA motherboard chipsets. The reason is that Creative bought their way into the PCI sound card market and didn't really understand how it worked for a long time...
Make sure to install the newest applicable motherboard chipset drivers you can find, and maybe look for PCI timing settings in your BIOS.
Reply 19 of 23, by swaaye
Some mobos have absolutely horrible PCI implementations. A combination of shoddy chipset design, board design and poorly programmed BIOSs. You just don't notice this with anything other than RAID and sound cards because most PCI cards don't need lots of bandwidth or tight latency. And sound cards give you nice audio feedback to let you know that things aren't pretty. 😁
I've run into problems with Vortex 2 and AudioPCI pops/clicks. Some video cards crank their PCI latency time to the max so they can hog the bus and this can cause problems for sound cards. I think that sound cards that process many channels in hardware are even more sensitive to it.
And yes AGP card latency affects the PCI bus.
