Prince of Persia (1989)
First post, by JonnyRobbienam.cz
im having problem with the prince of persia game in DOSBox. My UP key is dropping occasionaly. When I run and want to jump, it just wont jump and fall down the pit. My my keyboard is fine, because other games work properly. Does anybody know how to fix it?
Reply 1 of 7, by GSMIdol
i'm test play prince of persia 1 using dosbox 0.72 and got no problem, have u try press Ctrl + K in game to enable keyboard control?
Cheat any DOS Game - Cheat App for DOS
Cheat for DOS Game - Cheat App for DOS
Reply 2 of 7, by TomJeffersonJones
Are you sure? Prince of Persia's controls are a little weird, I recommend holding the up key well before the prince reaches the spot you want him to jump from. Tapping it doesn't always work for running jumps...
Reply 3 of 7, by JonnyRobbienam.cz
its not like it doesn't work at all....half the time the up key works, but sometimes it doesn't. And its like Im running, and want to jump and Im pressing the up key but not jumping and its really annoying. Tested on DOSBox 0.73 and 0.74 on Win7...
Reply 4 of 7, by eL_PuSHeR
Prince of Persia needs a very low cycle count. Tried any other cores and low cycles (3000)?
It seems to sort of work with 0.74 but it crashed to desktop when I got the sword. Using core normal and 3000 cycles. UP key seemed to work just fine though.
EDIT: CTD was due to using overlay on my Ati card. Using DDRAW is fine. Game works perfectly.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
Reply 5 of 7, by robertmo
what is your dosbox version and where have you got it from?
what is your Operating System?
what are your PC specifications?
post content of "DOSBox Status Window" (in Windows: right click on its title bar -> edit)
enclose your dosbox's config file
you need to press up when running jump 2 plates/bricks before the clif
Reply 6 of 7, by Johnatan
I just bought Prince of Persia (since it's on sale), and I can't get it to run.
From Steam it opens the launcher, but when I hit "Launch the Game!" it just closes the launcher and the game doesn't load.
I'm using Vista Ultimate 64-bit.
Reply 7 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
has nothing todo with us.
(different game)
Water flows down the stream
