First post, by JDog514
Hello,
I really enjoy DosBox and know how to change it to emulate a 386 etc. but is there a way to emulate a 8088 processor? Thank you very much.
Jeffrey M. Bouchard
Hello,
Jeffrey M. Bouchard
Why? a 386 should be capable to run 8088 code accordingly.
Intel i7 5960X
Gigabye GA-X99-Gaming 5
8 GB DDR4 (2100)
http://www.hampa.ch/pce/index.html
Haven't tried it yet, but it was recommended to me, when I wanted to run some old software that did not work on DOSBox.
Which?
thank you very much. I will just switch the mode to 386. The reason I did not want to do this is I was worried about speed.
wrote:I was worried about speed.
Cycles.
Klimawandel.
what would be a good cycle number to use say for a 4.77 mhz 8088? Thank you very much.
There's no perfect number, but I generally run at 500 cycles to approximate XT speed. It's worked well with pretty much everything I've tried.
My site: Ramblings on mostly tech stuff.
Thank you
