First post, by StarSword
I'm running The Elder Scrolls II: Daggerfall on DOSbox, but I'm having trouble activating a cheat code. Invulnerability's code is Ctrl-F4, which according to the Wiki is used by DOSbox for something else.
I'm trying to use the keymapper to reassign the key combo, but the article on the Wiki doesn't explain how to reassign key combinations. I need some help.
StarSword
Reply 1 of 1, by Kippesoep
Go into the keymapper, find the special functions block in the lower right, select the "rescan" function (which is what ctrl-f4 is bound to by default), then delete that combo. Unless you then assign another combination to the function, you won't be able to rescan the disks. This isn't a frequently used operation in most cases, but something to be aware of.
My site: Ramblings on mostly tech stuff.
