First post, by Wulf
I've managed to install this via DOSbox 0.74, and it works - albeit a little jerkily, I'll have to work on the framerate. But when I attempt to connect a joystick (Logitech Extreme 3D Pro), the cursor heads for the top left of the screen and stays there... I can, after a bit of struggling, activate the in game configuration routine, successfully, and it is fully configured in Windows, but it makes no difference.
Has anyone else seen this, and has a solution? The game's a bit hard to play by keybaord, and I find mouse control way too unstable (as in, my sub wanders all over the place).
edit: I have tried the various DOSbox joystick emulation settings.
