First post, by lvm
When dosbox goes fullscreen it changes screen resolution to 640*480 and restores original resolution after exit, and when display is connected to an ordinary DB-15 VGA port it works fine (except when dosbox crashes :) but when display is connected to the same system over HDMI screen resolution is not restored and remains stuck at 640*480. dosbox 0.74 on 32-bit linux (ubuntu 10.10), video ATI HD4590 (xorg ati drivers, NOT fglrx)
Reply 2 of 5, by SKARDAVNELNATE
That would be an issue with your video and driver as many programs that change resolution, including modern day games, will exhibit the same behavior.
Reply 3 of 5, by lvm
If we are looking for a guilty party I may suggest a compromise candidate - SDL, looks like dosbox calls SDL_Quit and relies on it to clean up with no attempts to save and restore screen resolution by itself. I added SDL_SetVideoMode(1920,1080... just before the SDL_Quit and the problem is gone. But it has nothing to do with video drivers - to clean up after messy programs is not the driver's job.
Reply 4 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
hmm so fullscreen doesn't come back to windowed before closing.
Water flows down the stream
Reply 5 of 5, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
It's the operating system's job. Even more so as programs sometimes don't quit normally.
1+1=10
