First post, by RogueTrip2012
- Oldbie
So now I own a Monster MX300 and a Aureal SuperQuad 2500 soundcards, both Rev. A. Does anyone have the user manuals for these cards? Been looking for a few days over google/bing but came up dry.
Also I got a NEC XR-385 (DB60XG clone) daughtercard in the mail. I can only assume its on the right connector of the SQ2500 right now but is there anything special to setting it up? I see in the Vortex MIDI "DOS Box MIDI Out" that Vortex AU8830 Wavetable is selected. There is also a MPU-401 that can be selected, using the MPU-401 makes Duke Nukem 3D loose music while the wavetable sounds good. On Duke Nukem 3D I setup just using the AWE32 settings which work but is this correct.
Sorry, Just can't find much info on these soundcards/daughtercards. Thanks!
