First post, by mathew.olufemi
We are using DOSbox to run certain scientific application on Win7. Our software needs to exit smoothly using its own quit command otherwise several configuration files get corrupted. The issue is that every now and then a student will close the DOSBox clicking on X of the session window, which produces a mess.
The question is if there is a way to disable the close window X?
Thanks
