First post, by DosFreak
- l33t++
VMWARE v3.1.1 Build 1790/VPC v5.0 Build 350
Both PC's using 16GB Expanding images.
Both tested under Windows XP Professional
Both tested with 256mb RAM
No additions on either OS but Video drivers from Vmware additions installed on Vmware
Host is Windows 2000 Advanced Server SP3
Both guest images located on same host partition.
Both guest OS's installed cleanly.
CD benchmarks were taken by using Daemon Tools on the host to emulate a WinXP Pro Corp CD.
CD was captured under the guest
Sisoft Sandra 2000 Professional SP1 v2002.6.8.97
CPU Arithmetic Benchmark
Dhrystone ALU: 4491MIPS/4053MIPS
Whetstone FPU: 2261MFLOPS/2039MFLOPS
Test Status
Parallel Test Execution: No
SMP Test: No
Total Test Threads: 1
SMT Test: No
Dynamic MP/MT Load Balance: No
Processor Affinity: No
Standard No Runs: 64000 / 640
Processor(s)
Model: AMD Athlon(tm) XP 2000+
Speed: 1.64GHz/1.61GHz
Model Number: 2000 (estimated)
Performance Rating: PR2398 (estimated) PR2354
L2 On-board Cache: 256kB ECC synchronous write-back
Front Side Bus Speed: 2x 149MHz (298MHz data rate) / 2x 146MHz (292MHz data rate)
Technology Support
SSE2 Technology: No
Hyper-Threading Technology: No
CPU Multi-Media Benchmark
Benchmark Results
Integer aEMMX/aSSE: 8962it/s / 8113
Floating-Point aSSE: 9937it/s / 8980
Test Status
SMP Test: No
SMT Test: No
Rendered Image Size: 860x570
Processor(s)
Speed: 1.67GHz / 1.60GHz
Performance Rating: PR2439 (estimated) / PR2338
Front Side Bus Speed: 2x 152MHz (304MHz data rate) / 2x 145MHz (290MHz data rate)
Technology Support
MMX Technology: Yes
SSE Technology: Yes
SSE2 Technology: No
Extended AMD MMX Technology: Yes
3DNow! Technology: Yes
Extended 3DNow! Technology: Yes
File System Benchmark
Hard Disk (C:)
Benchmark Results
Drive Index: 12773kB/s / 9701kB?s
Disk Status
SMP Test: No
SMT Test: No
Windows Disk Cache Used: No
Use Overlapped I/O: Yes
Command Queue Depth: 4 command(s)
Test File Size: 256MB
File Server Optimised: No
Benchmark Breakdown
Buffered Read: 44 MB/s / 85MB/s
Sequential Read: 16 MB/s / 14MB/s
Random Read: 6 MB/s /3814 kB/s
Buffered Write: 29 MB/s / 28MB/s
Sequential Write: 17 MB/s /9 MB/s
Random Write: 10 MB/s /3531 kB/s
Average Access Time: 7 ms (estimated) / 12 ms (estimated)
Drive
Drive Class: Fixed
Total Space: 16.0GB / 15.6GB
Free Space: 14.6GB, 91% / 14.0GB, 90%
CD-ROM/DVD Benchmark
Wxpvol_en (D:)
Benchmark Results
Drive Index: 76214kB/s / 10064kB/s
CD-ROM/DVD Status
SMP Test: No
SMT Test: No
Windows CD-ROM/DVD Cache Used: No
Disc Tested: Data CD/DVD
Test File Size: 73MB
Benchmark Breakdown
Drive Technology: 434x CD speed / 76x CD Speed
Track Speed: 229188 RPM (estimated) / 40134 RPM (estimated)
Buffered Read: 75 MB/s / 15MB/s
Sequential Read: 75 MB/s / 13MB/s
Random Read: 74 MB/s / 5 MB/s
Average Access Time: / 31 ms (full stroke, estimated)
Memory Bandwidth Benchmark
Benchmark Results
RAM Bandwidth Int Buffered aEMMX/aSSE:1941MB/s / 411MB/s
RAM Bandwidth Float Buffered aEMMX/aS:1844MB/s / 339MB/s
Int Buffered aEMMX/aSSE (Integer STREAM) Results Breakdown >
Assignment: 1938MB/s / 414MB/s
Scaling: 1945MB/s / 415MB/s
Addition: 1945MB/s / 411MB/s
Triad: 1937MB/s / 407MB/s
Data Item Size: 8-bytes / 64-bits
Buffering Used: Yes
Offset Displacement Used: Yes
Bandwidth Efficiency: 163% (estimated) / 35% (estimated)
Float Buffered aEMMX/aSSE (Float STREAM) Results Breakdown >
Assignment: 1948MB/s / 405MB/s
Scaling: 1862MB/s / 322MB/s
Addition: 1790MB/s / 309MB/s
Triad: 1779MB/s / 322MB/s
Buffering Used: Yes
Bandwidth Efficiency: 155% (estimated) / 29% (estimated)
Test Statistics
Memory Used by Test: 128MB
SMP Test: No
SMT Test: No
System Chipset
Model: Intel Corporation 82443BX/ZX 440BX/ZX CPU to PCI
Bridge (AGP Not Implemented)
Front Side Bus Speed: 2x 149MHz (298MHz data rate) / 2x 145Mhz (290MHz data rate)
Max. Bus Bandwidth: 2384MB/s (estimated) / 2320MB/s (estimated)
Logical/Chipset Memory Banks
Bank 0 Setting: 32MB EDO / 16MB EDO
Bank 1 Setting: 32MB EDO
Bank 2 Setting: 32MB EDO / 16MB EDO
Bank 3 Setting: 32MB EDO
Bank 4 Setting: 32MB EDO / 16MB EDO
Bank 5 Setting: 32MB EDO
Bank 6 Setting: 32MB EDO / 16MB EDO
Bank 7 Setting: 32MB EDO
Memory Bus Speed: 1x 149MHz (149MHz data rate) / 1x 145MHz (140MHz data rate)
Max. Memory Bandwidth: 1192MB/s (estimated) / 1160MB/s (estimated)
Instruction Set Support
MMX Technology: Yes
SSE Technology: Yes
SSE2 Technology: No
Cache & Memory Benchmark
Benchmark Results
2kB Blocks: 13317MB/s / 12341MB/s
4kB Blocks: 14096MB/s / 13051MB/s
8kB Blocks: 14428MB/s / 13431MB/s
16kB Blocks: 12308MB/s / 11478MB/s
32kB Blocks: 10234MB/s / 9532MB/s
64kB Blocks: 9488MB/s / 8915MB/s
128kB Blocks: 6170MB/s / 5578MB/s
256kB Blocks: 4803MB/s / 2953MB/s
512kB Blocks: 1053MB/s / 993MB/s
1MB Blocks: 904MB/s / 772MB/s
4MB Blocks: 898MB/s / 744MB/s
16MB Blocks: 896MB/s / 601MB/s
64MB Blocks: 893MB/s / 325MB/s
256MB Blocks: 0MB/s / 0MB/s
1GB Blocks: 0MB/s / 0MB/s
4GB Blocks: 0MB/s / 0MB/s
Float iSSE Cache/Memory Results Breakdown >
Data Item Size: 16-bytes / 128-bits
Buffering Used: No
Test Statistics
SMP Test: No
SMT Test: No
Processor(s)
Speed: 1.67GHz / 1.61GHz
Performance Rating: PR2437 (estimated) / PR2354 (estimated)
Internal Data Cache: 64kB synchronous write-back
Technology Support
SSE Technology: Yes
SSE2 Technology: No
System Chipset
Front Side Bus Speed: 2x 151MHz (302MHz data rate) / 2x 145MHz (292MHz data rate)
Max. Bus Bandwidth: 2416MB/s (estimated) / 2336MB/s (estimated)
Memory Bus Speed: 1x 151MHz (151MHz data rate) / 1x 146MHz (146MHz data rate)
Max. Memory Bandwidth: 1208MB/s (estimated) / 1168MB/s (estimated)
Network/LAN Bandwidth Benchmark
WORKGROUP
RON-W2KSRV
Benchmark Results
Network Bandwidth: 31500kB/s / 9000kB/s
Host >
IP Address: 192.168.245.1 / 210.220.230.100
Benchmarks Breakdown >
Average Latency: 1ms
Min/Max Latency: 1 - 5ms / 1 - 3ms
Transfer Rate: 31500kB/s / 9000kB/s
Final results:
CPU Arithmetic Benchmark: VMWARE
CPU Multi-Media Benchmark: VMWARE
File System Benchmark: VMWARE
CD-ROM/DVD Benchmark: VMWARE
Memory Bandwidth Benchmark: VMWARE
Cache & Memory Benchmark: VMWARE
Network/LAN Bandwidth Benchmark: VMWARE
