well, I lost my ebay bids.
Reply 20 of 22, by khalek
I have a PDF of the manual if someone would like to host it...
Reply 21 of 22, by Snover
You can ZIP it and just upload it here...
unless it's really huge, in which case send me a PM and I'll work something out.
Yes, it’s my fault.
Reply 22 of 22, by CapTVK
Finally got it, the CM-500 the final end of line for the LA-synthesis series combined with the GS Soundcanvas in one box. There's a little switch at the box that you can use to set it to CM-32L mode, CM-64 mod(ish, apart from the LA synthesis the GS 'emulates' the remaining CM-64 parts), CM-300 and CM-500 (CM-300 and CM-32L at the same time) .
Quelle surprise! Doesn't look much different from a regular CM-32L actually.
http://www.dearhoney.idv.tw/MUSEUM/Roland_CM-500.jpg
Service from Roland was top notch as usual. Called Roland and requested a manual. No problem, only had to pay a fee for the copy and p&p this time. Received my copy in a week, with compliments.
However, seeing the current situation. What use is it at this point? 😕
