First post, by Barry_Purplelips
Before I get into specs and everything else pertaining my PC, what could possibly cause DOS 6.22 to only detect 15mb out of all the available ram memory which amounts to a massive (for a retro rig) 1024mb?
I know DOS software has it hard detecting high-end single-core CPU's, and perhaps it's mistaken mine for one of those ancient CPU's whose architecture couldn't handle more than 15mb's, or perhaps it's merely a bad combination of memory settings.
Any thoughts?
Reply 1 of 16, by sliderider
What CPU are you using? 286 and 386SX have a hard limit of 16mb of addressable memory IIRC.
Reply 2 of 16, by Barry_Purplelips
P4 3.8ghz
Reply 3 of 16, by sliderider
Well according to this page
http://www.computing.net/answers/dos/memory-l … -622/14433.html
DOS 6.22 has a 64mb memory limitation, so even if you manage to get your problem solved, 6.22 is still not going to allow you to use all your memory. Later versions may ease the memory limitation but I'm not sure if they will go all the way to 1gb. DOS may also be having issues with your CPU. I know Windows 95 and 98 have issues with CPU's above 2.0 ghz so DOS may have a similar problem. The problem for Windows 95/98 was fixed with a patch (which you have to hunt for because I don't think Microsoft has it for download anymore) but I don't think they would have bothered to fix DOS.
Reply 4 of 16, by sklawz
lo
no idea if this is relevant but play with that
obscure option in the bios called 1mb memory
hole which so happens to be between 15-16 MB.
bye
Reply 5 of 16, by Barry_Purplelips
All I want is 64mb to be detected, there really is little point in going higher than that for 99.99% of the DOS applications.
Reply 6 of 16, by AdamP
I think this is unlikely to be the problem, but it's worth a shot asking. What version of himem.sys are you using?
Reply 7 of 16, by Barry_Purplelips
DOS 6.22's.
It's worth noting that advanced memory managers such as QEMM may detect the whole thing and address as much as 256mb, but somehow they tend to break compatibility with certain games and I don't have time to go through a crapload of settings to locate the offender.
Reply 8 of 16, by shspvr
The reason you only see 15Mb it extended you forgot take in count of 1Mb conventional and upper memory equals 16Mb
Sound like you don't have something config rigth
You know MS-DOS 7.10 will recognize much more memory than 64MB and so will FreeDOS
As for QEMM you want 7.5 and is 256Mb limitation from what I recall
Reply 9 of 16, by tikbalang
OP needs an XMS driver. XMS2 can see 64mb (himem.sys from msdos 6.22). XMS3 can see all (himem.sys from later versions of win9x). it is the dos apps that cannot see it so you need to use a virtual ramdisk to make use of the rest of ram. that's how i understood it back then.
ESS PCI DOS Drivers
_________________
Reply 10 of 16, by elfuego
sklawz wrote:
lo […]
lo
bye
This is my guess also. Try the BIOS and search for such an option.
Reply 11 of 16, by h-a-l-9000
Rank DOSBox Author
DOSBox Author
himem.sys from win98 brings at least 2GB to MSDOS 6.22
1+1=10
Reply 12 of 16, by Barry_Purplelips
Thank you all for the suggestions. I'm definitely going to try luck with Win98's himem.sys as 6.22's isn't doing the trick, and I can only wonder why.
Reply 13 of 16, by shspvr
Make sure it one from Win98 Second Edition and not Win98 Gold Edition
Also make sure you disable OS/2 64MB option set it to NoN-OS2 this know cuases problem as well
As sklawz point out some bios motherboard may have this option know as Memory hole at 15-16 MB you should disable it and if your motherboard has no ISA you will bot see that option.
The one you want himem.sys, 33191
Reply 14 of 16, by SavantStrike
shspvr wrote:
Make sure it one from Win98 Second Edition and not Win98 Gold Edition Also make sure you disable OS/2 64MB option set it to NoN- […]
There was a gold edition?
Now you've got me curious here 😀.
Reply 15 of 16, by shspvr
It gose like this
Windows 95
Windows 95A with Service Pack 1 or as OSR 1.0
Windows 95B OSR 2.0
Windows 95B OSR 2.1 with USB Supplement
Windows 95C OSR 2.5 with USB Supplement and IE4
OSR = OEM Service Release
Windows 98 First Edition aka Gold
Windows 98 Second Edition aka SE
Windows Millennium Edition aka ME
There are 4 ver Microsoft Plus! = 95, 98, Kids and Game Pack
I was beta tester for ever one of ver above even WinNT4, WinNT5 aka Windows 200 and Windows XP
I hated ME and drop out of Vista half done I didn't want deal with carp agine like ME boy I was rigth Vista was a major failer.
Reply 16 of 16, by Barry_Purplelips
Ok, I finally got around replacing himem.sys and it worked beautifully 😎 Not sure how much it actually managed to allocate, but the ancient mem.com reports about 68mb, which's more than enough anyways.
It's case closed for me I guess. Thanks everyone for your help.
