First post, by bobistheweatherman
I noticed everytime I go into full screen it's way too large. Anyone know how to fix this?
Reply 1 of 12, by canadacow
Uhm... buy a smaller monitor? Adjust the vertical and horizontal to make the screen display smaller? These games appear big because the resolution was was so low during the time those games were made.
Reply 2 of 12, by eL_PuSHeR
Under DOSBOX configuration file put Keepsmall=true and scalers=none
Reply 3 of 12, by Harekiet
Rank DOSBox Author
DOSBox Author
config options were changed.
But i kinda wonder what he means with way too large .
Reply 4 of 12, by bobistheweatherman
Large as in everything can't fit on the screen.
Also the config changes didn't work for me.
Reply 5 of 12, by HunterZ
I would guess that you either need to disable scaling or adjust your monitor settings to make the picture smaller, as others have suggested. If these solutions don't work for you, then please explain in detail why.
Reply 6 of 12, by Snover
Scaling would not be the issue...
Yes, it’s my fault.
Reply 7 of 12, by bobistheweatherman
I can change the screen size a bit, but it looks pretty distorted. I'm at 1024 by 768 resolution if that helps.
Reply 8 of 12, by HunterZ
I'm pretty sure that DOSBox uses the original resolutions when running full-screen. Are you using an LCD monitor?
Reply 9 of 12, by bobistheweatherman
No.
Reply 10 of 12, by Snover
Then you need to adjust your monitor. The little buttons under the screen, the little buttonssss!!
Yes, it’s my fault.
Reply 11 of 12, by bobistheweatherman
Ok I could do that, but I won't. 😉
Dosbox .58 worked fine with my same monitor, so I dunno what to say. 😕
Reply 12 of 12, by Snover
It might be using a different refresh rate! Reeefresh raaate!
Yes, it’s my fault.
