First post, by own3mall
I have the joystick problem when playing Tomb Raider 1 which makes the menu ring go round on its own. If I go to controls in Tomb Raider 1 and change anything, the game freezes. I have even unplugged my controller, launched Glidos, and have just tried to change the controls on my keyboard. Nothing works. I cannot change the controls or the game crashes.
Any idea why and what I should do? I can't use either of my controllers, as my Microsoft Sidewinder and my Playstation controller plugged up through my TrioLinkerPlus II Adapter run into the same problem.
I tried adding the following to my dosbox.conf in C:\Program Files (x86)\Glidos (I Found this Somewhere Online)
joysticktype=ch
timed=false
autofire=false
swap34=true
buttonwrap=true
But nothing changed.
Also, does Glidos support custom resolutions such as 1920 x 1200? I'd love to run TR1 at my native resolution if possible.
Please let me know.
Reply 1 of 16, by Glidos
Sorry, this may be a daft question, but is there any chance you have Glidos configured to use VDos32 rather than DOSBox. Obviously that cannot be the case if you are running on a 64bit OS, but just thought it was worth asking because I know that VDos32 freezes if you try to change the keys.
Reply 2 of 16, by own3mall
Yes, I'm using the 64-bit dosbox version you included on your website.
Reply 3 of 16, by Glidos
Oh ok. Then it is definitely a DOSBox issue. Glidos doesn't interact with the joystick. I'm no DOSBox expert. Do you know of a way to tell DOSBox there is no joystick?
Reply 4 of 16, by own3mall
Yeah, I can unplug the joystick, and it's no longer identified. However, with no joystick plugged in, I still can't change key mappings, because the game crashes as soon as I change any setting.
Are the controls stored in a config file somewhere that I could edit manually? Perhaps I should try setting up my controls using the latest DosBox and see if they carry over to version .73?
Does Glidos support 1920 x 1200?
Reply 5 of 16, by Glidos
That's odd. I just changed Run from PAD0 to T under user settings and it looks to have worked. Are you using the TR1 installation downloaded from the Glidos web site? Strange that we see a difference. Our set ups should be identical.
Worth a go. I was in any case thinking of rebuilding the Glidos version from the latest source.
Yes and no. Glidos can work in a 1920 x 1200 mode producing two black bars at the edge. That what the "inhibit mode change" setting is for. But it's the games themselves that cannot fill other than a 4x3 area. There's nothing that Glidos can do about that.
Reply 6 of 16, by Famicom
So what has to be done to run it at a custom resolution apart from checking the "inhibit mode change"? Because even then, all the possible resolutions are: 640x480, 800x600, 1025x768, 1280x1024 and 1600x1200. How can I make GliDOS render the game at 1400x1050 (4:3)?
My screen res. is 1680x1050 (16:10).
Reply 7 of 16, by Glidos
Ooo, my screen is 1680x1050 too. I'm tempted to add 1400x1050. Not trivial though, because it has to go though.
Reply 8 of 16, by Famicom
1400x1050 and 1440x1080 would just be awesome. Just saying 😉
Reply 9 of 16, by Famicom
By the way, like own3mall, if I try to map the controls to my joypad from within the game menu, the game freezes. The menu rolls too...but you already know that, a DosBox issue. I'll try to find out how to solve it.
Reply 10 of 16, by sliderider
If you try to blow up a game written for a lower resolution, doesn't pixelation become an issue like blowing up a low resolution photograph on a much higher resolution monitor?
Reply 11 of 16, by Glidos
Pixelation isn't a problem because it isn't the frame buffer that is scaled; the coordinates are altered within the games 3D graphics rendering commands. With the TRX texture packs, you need the extra resolution to expose all the detail.
Reply 12 of 16, by sexyjw
I had exactly the same issue. Try adding the following to the installed dosbox.conf file. Worked a treat for me.
[joystick]
joysticktype=none
Source: http://www.dosbox.com/DOSBoxManual.html#Joystick
I then simply use my gamepad's programming mode (SST) to emulate DOS keys.
Cheers
JW
Reply 13 of 16, by aub84
sexyjw wrote:
I had exactly the same issue. Try adding the following to the installed dosbox.conf file. Worked a treat for me. […]
[joystick]
joysticktype=none
What program? How it works?
Reply 14 of 16, by sexyjw
That depends on the gamepad. Though I'm sure other keyboard emulation programs have been mentioned in another recent thread.
Cheers
JW
Reply 15 of 16, by sexyjw
[joystick]
joysticktype=none
See the "New (to me) issues regarding Tomb Raider and GliDOS" thread. Famicom mentions xpadder.
Cheers
JW
Reply 16 of 16, by aub84
sexyjw wrote:
[joystick]
joysticktype=none
Yes, xpadder is the solution. Thanks!
