First post, by shorty
Hi!
I tried to run my sblive (emu10k1) with gm support in dosbox on windows xp. But i can't get a sound ...
my [midi] conf is:
mpu401=uart
mididevice=win32
midiconfig=0
i also have a second computer with gentoo linux. Its the same soundcard in it. There' s no MIXER /LISTMIDI command - how do i get the midi port of this device?
[midi]
mpu401=uart
mididevice=alsa
midiconfig=0
what did i wrong, i just want to have general midi sound in my old games.
thanks for the help so far (sorry for my broken english)
perhaps somebody knows how i configure the joystick to this device ??
    5 KiB
Reply 3 of 7, by Qbix
Rank DOSBox Author
DOSBox Author
for plinux use pmidi or amidi to get the port number you need
For the soundblaster live to have midi support, you need to have a soundbank loaded. (has nothing to do with dosbox). Did you do that ?
Water flows down the stream
Reply 4 of 7, by shorty
of course i did that - i loaded a soundfont with asfxload ...
    24.75 KiB
Reply 5 of 7, by batracio
shorty wrote:
mpu401=uart
mididevice=win32
midiconfig=0
Under Windows XP, Your EMU10K1 Synth devices seem to be listed as ID #0 and ID #2. Therefore, this config should work fine, but you must permanently load a SoundFont (SF2LOAD won't work - use AudioHQ control panel).
shorty wrote:
mpu401=uart
mididevice=alsa
midiconfig=0
Under Linux, your EMU10K1 Synth devices seem to be listed as ID #1 and ID #2, while ID #0 is EMU10K1 MPU-401 emulation. You won't get any sound here unless you have some external device connected to your SB Live. Try to change your MIDI device ID to "midiconfig=1" or "midiconfig=2".
Reply 6 of 7, by shorty
yes, the windows conf works fine ...
i just had to pull up the controller and set the irq to 2
(standard soundfont already loaded)
thank your for your instructions
    30.84 KiB
Reply 7 of 7, by shorty
fine, now midi works in linux too - i just emerged timidity and put that in the conf :
[midi]
mpu401=intelligent
#mididevice=alsa
#midiconfig=1
device=alsa
config=128:2
is there another option to setup the capture on other keys? i don't want to switch my session with CTRL+ALT+F5 ...
