Reply 40 of 54, by RichB93
- Member
Here ya go http://www.mediafire.com/?wk6ucgm16bd3p5g 😀
wrote:wrote:If it uses a 16-bit installer, isn't there a good chance that the .exe will also be 16-bit?
No, it is fully 32-bit. I don't understand why they used a 16-bit installer, although I have seen it done on a few games as well for some reason 😒
That nothing new they most likey just to lazy to update software
wrote:wrote:wrote:If it uses a 16-bit installer, isn't there a good chance that the .exe will also be 16-bit?
Who's going to bother updating the installer on a 12 year old demo for a card they don't even sell anymore? It's only crazy people like us who bother tracking these things down any more.
wrote:Here ya go http://www.mediafire.com/?wk6ucgm16bd3p5g 😀
Hmmm...it crashes out and Windows attempts to look for a solution to the problem. I'm running in Windows 95 compatibility mode.
wrote:wrote:Here ya go http://www.mediafire.com/?wk6ucgm16bd3p5g 😀
Hmm, same as I got unfortunately. I have a feeling that it won't work on Windows 7 🙁
Here's the cool music from the demo if anyone wants it. (I've compressed it to FLAC from the original WAV)http://www.mediafire.com/?bmloe72awz5w89a
I've been talking to the uploader of the YouTube video, Hypernl and he found out that you can use the decompressed audio with the RAS file intact (rather than extracting the whole lot). While this takes up a little more space, it is a lot neater and leaves the original audio intact too. It also *appears* to improve stability with the MAX-FX engine the demo uses.
You can download it here http://www.mediafire.com/?w0h17tz61o1b4bh
Very interesting! I'll see if I can get the stuff working on nvidia cards, if it does not. =]
wrote:wrote:Yup I checked my ATI Rage Fury Pro CD Release 109B, No Dawning Demo, just Hydra demo.
megatron-uk and RichB93 thanks for providing us with links to this demo, I've seen it requested on numerous forums while googleing, no one knew where to find it.
You're welcome 😁 What is the Hydra demo? If it's not too large could you upload it please? Would be nice to get some other bits for the Rage Fury series of cards as my Maxx CD was so barren.
It's in a directory called HVISION on the CD. I checked the INSTALL.INI & SETUP.INI files and it's something called Hydravision Radeon's Ark.
Anyway it's only 2.19 MB so here it is:
http://www38.multiupload.com/files/7A923275A9 … 0E3/HVISION.zip
And a download mirror in case the first one is busy or slow:
http://www.megaupload.com/?d=5XBJAQO4
I never tried this demo or anything else on the CD other than the drivers, video capture components and the DVD player. The DVD player sucked, it sputtered and sound was out of sync whereas VLC played it smoothly.
These demos are great, real blast from the past. The windows 7 fixed RAGE one works fine on my 580GTX, I can't get the matrox one to work though, just stuttering music and black screen.
I'll try the HVISION one in a bit. =]
wrote:These demos are great, real blast from the past. The windows 7 fixed RAGE one works fine on my 580GTX, I can't get the matrox one to work though, just stuttering music and black screen.
Further than I got, the Matrox one just flat out crashes on my Windows 7 machine. Runs on my old PC though.
The Hydra app is the HydraVision software used for dual head graphics cards.
Hmm, just reading through the RAGE 128 Pro reviewers guide, and there was another demo developed for these cards called radiATIon. I've only been able to find screenshots of it online though... 😢
no sound here on my Q9300... maybe it needs some old OS to get it working
wrote:Hmm, just reading through the RAGE 128 Pro reviewers guide, and there was another demo developed for these cards called radiATIon. I've only been able to find screenshots of it online though... 😢
Have you found the Ark demo yet? That is supposed to use the same technology as the RadiATIon demo.
I tried to run the demo with R7 360 in the past and worked OK.
Now with RX 6650 XT it gives me this VertexBuffer error. I tried with dgvoodoo with no luck.
Any suggestions?
80c88WildXT wrote on 2024-09-03, 14:50:I tried to run the demo with R7 360 in the past and worked OK.
Any suggestions?
SurfaceLost appears when the app is unfocused when running. Either you are pressing the Windows button, or some button that focuses some other app (and brings 3dmark out of focus) or some app doesn't let 3DMark to focus
