First post, by dejanr
Is it possible to use my own favorite font in the DOSBOX window? The font is attached - it is a console font, works well in the DOS window of 32-bit Windows.
I tried to load the font from within DOSBOX, but did not know how. In Windows I just select Properties / Font and select Raster Fonts, and then 11x20 font and it just appears.
Please help.
    MYFONT.ZIP
    2.97 KiB
    315 downloads
    Font
Reply 1 of 4, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
No
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 4, by Qbix
Rank DOSBox Author
DOSBox Author
you can do it the same way as you did in the DOS days. (it's a table in the emulated memory, easy to change with an utility or TSR)
However you can't do weird resolutions as 11x12
Water flows down the stream
