First post, by CraigG
- Member
If anyone's interested, I've been doing some extensive tests under WinXP for Screamer2, and I've solved the No CD problem by using Diskjuggler to make an image of the CD, and DAEMON Tools to mount the image.
Just install from the mounted image and it runs a treat.
But it's very slow under any GliDOS settings.
I have used FRAPS to show the exact FPS when GliDOS games are running, represented by the yellow Number at the top
Athlon 64 3000+ stock
MSI NForce 4 K8N Neo Platinum
2Gb RAM
nVidia Geforce 6800GT stock clocks
SBLive! Platinum + Audigy ZS2 Drivers
WinXP Pro SP2
