First post, by XOPEK
Hi everyone! I have some kind of problem with DOSBOX +EF2000+CH Fighterstick .
It begins from config: when i try to calibrate X&Y axis the arrow in the calibration screen looks to the left lower corner even after i moved it through the circle.The thrust axis also shaking & calibration arow do not moves at all when try to move it from min to max position. After start of the flight- the plane begin to spin around his axis & thrust do not work.
By the way in windows (using CH Control Manager ),all is ok(i mean -it calibrates fine,all buttons work properly). Do anybody have(had) such trouble?Is it some solution exists for that trouble ? Thanks for your answers!
p/s My system specs:Core2Duo E8500,260GTX,4Gb RAM,Windows Xp & 7
