Reply 120 of 227, by robertmo
- l33t++
wouldn't it be easier to make one diff with all of them right now?
The following steps are important for saving/loading procedure.
Run an app -> Save state to disk -> Exit DOSBox -> Run the app again -> Load state from disk
Just saving/loading without restarting DOSBox seems to be okay though.
@robertmo
I have a good amount of debug + debugger + cheats + misc + experimental stuff in my modified build. Can't just simply 'diff'. 🙁
@ykhwong
Okay, I understand now. You're loading a loadstate at the CMOS screen (before the game fully boots up)?
That doesn't work yet. I normally wait until the game fully boots, then loadstate. That's worked okay for me to date.
I think it has to do with 'un-init' data that gets 'init'ed at usage run-time. May look into this.
Archive of savestate diffs - each one is to be used with a clean svn 2012-02-20 build.
Added TheGreatCodeholio's GUS stereo patch also.
011
midi_mt32.h
- using sergm's syncthread file
+ added class MidiHandler_mt32 functions
- GetSynth
- Reset
+ added class RingBuffer function
- reset
midi.cpp
+ Updated to MT-32 sergm class POD format
dosbox.cpp
- using sergm's new MT-32 config format
012
cpu.cpp
+ proper 'cpudecoder' POD
paging.cpp
- remove 'static' from PageFaultCore
iohandler.cpp
- remove 'static' from IOFaultCore
Applying patch 011 will install -all- updates from 001-011.
Applying patch 012 will install -all- updates from 001-012.
NOTES:
011 = uses sergm's new MT-32 code syncthread method
- faster than old multicore method
- doesn't lockup at boot (old code had a rare lockup bug)
- multicore handles buffers > 255 bytes (old bug too sometimes)
mt32.reverse.stereo=off
mt32.verbose=off
mt32.thread=off
mt32.dac=0
mt32.reverb.mode=auto
mt32.reverb.time=5
mt32.reverb.level=3
012 = proper cpudecoder POD support
- fixes loadstate lockups from CMOS
- fixes random loadstate lockups from HLT exceptions
013
mixer.cpp
+ Rework channel POD state (vars)
+ Add 'enabled'
- Remove 'done', 'needed', 'last'
(Reset mixer vars instead on loadstate)
void MixerChannel::SaveState( std::ostream& stream )
void MixerChannel::LoadState( std::istream& stream )
gus.cpp
+ Add mixer channel savestate POD
void POD_Save_GUS( std::ostream& stream )
void POD_Load_GUS( std::istream& stream )
NOTES:
Fixes missing mixer sounds on loadstate (from CMOS or pre-init sound device).
ex. Loadstate 'Another World' from CMOS prompt or title screen (fixes sblaster sounds)
GUS should be fully supported now.
ex. Blackthorne title 'shotgun' SE using GUS (edit: when loadstate from CMOS)
I applied your last patch (savestate_013_mixer_channel) and everything seems to work except midi which causes freezing even on runtime.
Edit: I removed this code in setbytes.
MIDI_State_LoadMessage();
That's an interesting place for a bug. But it doesn't happen for me. 🙁
(Roland virtual SC-55 map = Betrayal at Krondor)
mpu401=intelligent
mididevice=win32
midiconfig=2
mt32.verbose=off
mt32.thread=on
mt32.dac=1
mt32.reverb.time=5
mt32.reverb.level=1
(MUNT MT-32 = Space Quest 3)
mpu401=intelligent
mididevice=mt32
midiconfig=2
mt32.verbose=off
mt32.thread=on
mt32.dac=1
mt32.reverb.time=5
mt32.reverb.level=1
Haven't had any crashes with either. Hmm. Wonder what's wrong.
014
midi.cpp
+ Add real-time MIDI savestate feature
MIDI_State_SaveMessage
NOTES:
This should fix the MIDI crashes. Wasn't there before. Which is probably why LoadState would crash (tries to send -all- junk data on all channels).
And I've noticed a CMOS load problem with Krondor (mouse). Will look at probably.
I forgot to say that I also found a crash with setting machine=cga, pcjr, hercules, tandy.
Quite late for me. I've got the original SQ3 (cga, ega, tandy, pcjr) floppy disk so I'll try them out with Dosbox later this week.
I wouldn't be surprised if CMOS loadstate crashes them though (MMIO handler not done).
015
dma.cpp
+ Add POD save/load DMA_controller NULL checks
void DmaController::SaveState( std::ostream& stream )
void DmaController::LoadState( std::istream& stream )
NOTES:
Should fix savestate crashes with tandy / cga modes. And likely pcjr.
Yes, that fix works as expected for those machines. 😀
The midi does not cause crash. However, MIDI_RawOutByte() is still stucked while loading states. I am looking into this.
Ugh. Guess I'll try a very clean build and see how it goes on my end.
016
mouse.cpp
+ Add full POD support
dosbox.cpp
+ Add Sdlmain POD support
sdlmain.cpp
+ Add mouse autolock POD support
NOTES:
Fixes Krondor mouse loadstates from CMOS.
Now I notice that CMOS Krondor loading doesn't detect my in-game saves. o_o
017
dma.cpp
+ Compile error: Add missing sstream header
+ Add class DMAChannel functions
(avoid raw class POD saving)
dma.h
+ Compile error: Add missing DMAController prototypes
poly.h
+ Compile error: constuctor
sdlmain.cpp
+ Add sergm MT-32 changes (GUI options)
memory.cpp
018
int10_char.cpp, int10_putpixel.cpp
+ Use h-a-l-9000's pcjr patch
NOTES:
017 = fixes compile errors, add -missing- memory POD
(fixes more loadstate crashes / hangs)
018 = adds h-a-l-9000's pcjr patch
I've changed dma.cpp to -not- write out a -class- as a raw POD. Heard this can cause unexpected problems.
When I mention CMOS, I've disabled the loadstate program check (my private build only). So I'm at a pure CMOS prompt when doing loadstate testing.
If external midi still locks up your emulator, only the non-sysex flushing would cause a pure problem. Are you hooking up a real mt-32?
wrote:If external midi still locks up your emulator, only the non-sysex flushing would cause a pure problem. Are you hooking up a real mt-32?
No, I am using default Windows midi device.
Edit: I had to remove "while( midi.cmd_pos != 1 )" in MIDI_State_LoadMessage() to make it work.
019
midi.cpp
+ Add midi msg reset (loadstate)
+ New midi cmd flushing method (loadstate)
midi_mt32.h
+ Using 'pure' dac = set 1/2 reverb output gain
(per readme)
NOTES:
New MIDI loadstate handler - throws invalid messages to cut current transfers. Also fixes a MIDI loadstate bug caused by random results of interrupting a MIDI transfer.
And forcing MUNT 'pure dac' to set reverb gain to 1/2 of 'normal dac' (readme). Doesn't seem to normally do this from what I can see in MUNT.
I kinda see where the DOS file loading problem is (CMOS loadstate). Still need to what to do about this.
020
dos_files.cpp
= Change to class POD support (Files)
= save state rewrite (class POD support)
dos_system.h
+ Add POD support (DOS_Drive)
= Change to class POD support (DOS_File)
= Enforce virtual use (DOS_Drive)
drives.cpp
+ Add POD functions (DOS_Drive)
part.h
= Enforce virtual use (Part)
cpu.h
= Enforce virtual use (Descriptor)
(misc cleanup)
NOTES:
Big thing is DOS drive POD - saves current directory. Fixes missing file errors (ex. loading Krondor from CMOS)
Reworked DOS files POD to be cleaner - relies on classes to do work.
Added in virtuals to enforce that the right POD structure is saved (fixes possible errors with MUNT rhythm + CPU descriptors)
POD support should be functioning at a high stable level. Minus Adlib or Paging. Or some rarer stuff like xms/ems callbacks. Or glide.
Haven't had any MIDI hangs yet.
021
midi.cpp
+ Fix MIDI polyphony (+ aftertouch poly) (loadstate)
022
midi.cpp
+ Fixes a big logging mistake in setting note-off polyphony
NOTES:
Can re-use old savestates from 021.
