[retro swim] - An episodic video tour of SquallStrife's retro junk
Schedules and announcements about program releases.
Postby SquallStrife » 2012-6-25 @ 12:58
So, I'm doing a Youtube series. Hurrah for me.
http://www.youtube.com/user/RetroSwim
Episode 1 is just me having a bit of practice at speaking for a camera, and editing my video on iMovie. I think I did alright for a first timer! :P
What I aim to eventually do, is episodes on my retro PC and console collection, and do LGR/ADG style commentaries on my personal favourite retro games.
The first feature (or story arc, I suppose) will be my project to change over all my consoles from using composite video to using RGB. I've started buying the connectors I'll need, and once I have everything, I'll cover making the cables, performing console mods where needed, and the differences in picture quality before and after.
Well, now that the video is in the wild, I throw myself at the mercy of the Internet. What do you think?
[retro swim] | Link | Release Thread
Regular silliness on Twitch!! http://www.twitch.tv/RetroSwim (8PM Mon, Wed, Sat AEST)
User avatar
SquallStrife
Re: [retro swim] - An episodic video tour of SquallStrife's retro junk
Postby keropi » 2012-6-25 @ 14:15
awesome, thanks for sharing! :) will watch it later at home :blush:
User avatar
keropi
Postby Markk » 2012-6-25 @ 14:21
Cool! I haven't seen that watch for about 20 years. A friend used to wear it at school, and it was looking so hi-tech at the time. I'm looking forward to your next videos.
User avatar
Markk
Postby SquallStrife » 2012-6-30 @ 22:46
User avatar
SquallStrife
Postby Stull » 2012-7-01 @ 01:44
Pop that 5.25" bay cover back in place, man! And use an air duster on those cards! AhhhHHH!!! Breathe.. breathe.. OCD attack..
(P.S. I enjoyed the video. :))
User avatar
Stull
Postby Mau1wurf1977 » 2012-7-01 @ 02:54
Awesome stuff! Thanks for creating these videos :)
User avatar
Mau1wurf1977
Postby Gemini000 » 2012-7-01 @ 03:14
*watches both episodes*
It's a start. Based on my own experience with Ancient DOS Games, here's some recommendations I have for you.
1. Write scripts. Yes, I know, to the vast majority of people who start a new web show, scripts are evil and they don't want to make them. But trust me when I say, without several years of practice and experience, this is the only way you will ever eliminate the uncomfortable gaps in your speech and you will be able to condense a lot more information into a smaller amount of time.
2. Volume balance. The music you run in the background when you're not talking is far louder than your vocal volume. Voice recordings usually end up much quieter than the typical volume levels of music and sound effects so you will need to lower the volume of such things so that it never exceeds the volume level your voice reaches. Always make sure to proof your final rendering before uploading to be sure everything works out.
3. The simplest way to eliminate flicker if you need to record a screen is to make sure that screen is an LCD. The flicker you ran into is a result of CRT refresh rates, which cameras will generally pick up due to the way they work.
As a side note, I actually have a calculator watch, though I never wear it anymore because the battery only lasts 1 1/2 years and replacing it always wipes all of the data stored, even when following the replacement instructions flawlessly. :P
--- Kris Asick (Gemini)
--- Pixelmusement Website: www.pixelships.com
--- Ancient DOS Games Webshow: www.pixelships.com/adg
User avatar
Gemini000
Postby Mau1wurf1977 » 2012-7-01 @ 05:15
I really like these RAW shows. They give you more time to absorb the moment.Yes other shows are packed with information but often I struggle to decide if I should listen to the comments or watch the video. Especially confusing if they cover different topics. But that's just me :)
User avatar
Mau1wurf1977
Postby Gemini000 » 2012-7-01 @ 05:23
Mau1wurf1977 wrote:I really like these RAW shows. They give you more time to absorb the moment.Yes other shows are packed with information but often I struggle to decide if I should listen to the comments or watch the video. Especially confusing if they cover different topics. But that's just me :)
Goes to show that everyone has different tastes. Even though I have a much lower viewership with ADG than Clint does with LGR, a few of my viewers have told me that they prefer my show over his.
Riffing though, (doing a show without a script), is extremely difficult. Not many people can pull it off better compared to having a script. I started scripting with Episode 16 of my show and the difference in my voiceover quality is VERY noticable! :O
User avatar
Gemini000
Postby SquallStrife » 2012-7-01 @ 05:46
Thanks for the pointers, Gemini! :)
I am kind of shooting for the "RAW" thing that Mau1wurf is talking about. I do have a script, kinda, it's more of a bullet list so I'm not yammering about things in a crazy order, like I would do in real life. Honestly, try to have a conversation with my IRL, it can be quite hard to follow.
I talk slowly in real life too, so what you're hearing WRT speech speed is just me, no amount of planning would change that. The long pauses are also partially due to my weak edit-fu. I closed up the gaps as best I could, but iMovie isn't the best tool in the world.
Volume is an odd one, iMovie has controls to automatically reduce the music volume while speech is being played. ("Ducking" they call it), but perhaps I missed enabling it on one or two of the voice clips? Or perhaps when I normalised the clips it came out wonky... I'll need to watch it beginning-to-end again. I did so before I uploaded it, but it was pretty late. Thanks for mentioning it, by the way, if nobody mentions stuff like that, I can't fix it! :)
Flicker, yeah, I figured an LCD would give better results. Medium-to-long term, I have a plan to buy one of those VGA capture cards like elianda has. But in the mean time, I've discovered that by twiddling with the camera's exposure settings, I can nearly eliminate flicker, so I'll be trying that out next time I need to record footage.
Honestly, I'm surprised my little vids have been received as well as they have. It's encouraging, thanks! :)
User avatar
SquallStrife
Postby luckybob » 2012-7-01 @ 07:25
I think the only person that does a GOOD job of unscripted commentary is paul soares jr. He started doing minecraft tutorials back in beta 1.7 and has continued to this day. he also does play-throughs of some other series. Most notibaly his DAY-Z which caused my wallet to open and me actually buy the game.
http://www.youtube.com/user/paulsoaresjr
User avatar
luckybob
Postby Mau1wurf1977 » 2012-7-01 @ 07:49
All my videos are unscripted. Main reason is becaue it is a hobby for me and if you want to make it appear more professional I would have to invest heaps more time and money (for some more advanced capturing and authoring software).
Gemini000 will know all about this :) I usually just throw it together in Movie Maker and then crunch it with Handbreak and I am done. I have a modern i5 so encoding takes a few minutes tops.
User avatar
Mau1wurf1977
Postby Markk » 2012-7-01 @ 08:26
Nice!
User avatar
Markk
Postby SquallStrife » 2012-7-04 @ 05:41
Stuff has started arriving for my RGB conversion project:
10 of these guys:
20m of this stuff:
User avatar
SquallStrife
Postby Mau1wurf1977 » 2012-7-04 @ 06:56
Woa Scart RGB conversion? Do you have any 15KHz multisync monitors? Looking forward to seeing how you go and what plans you have :)
User avatar
Mau1wurf1977
Postby SquallStrife » 2012-7-08 @ 13:22
I don't have any monitors per-se, but I do have a reasonably high-end TV that I intend to use. I have a 25" Sony broadcast monitor, but that's permanently attached to my Neo-Geo MVS cabinet.
Episode 3 is uploading as we speak, I've done a quick rundown of my console and console-game collection. Not a big collection compared to some out there on Youtube, but I'm not really a completionist, I just buy the games that I like, or that I want to play.
My RGB to YUV box should arrive this week, so I can start actually making my cables up and testing them. Making footage all along the way, of course! :)
User avatar
SquallStrife
Postby SquallStrife » 2012-7-08 @ 19:59
User avatar
SquallStrife
Postby Stull » 2012-7-09 @ 21:54
It's always fun to journey through others' nerd caves. Do you notice much video degradation using so many A/V switches right now? Also, you seem to be lacking Shining Force for your Mega Drive. :D
User avatar
Stull
Postby SquallStrife » 2012-7-09 @ 23:13
Stull wrote:It's always fun to journey through others' nerd caves. Do you notice much video degradation using so many A/V switches right now? Also, you seem to be lacking Shining Force for your Mega Drive. :D
Surprisingly no, before I had the switch boxes I used to just swap the leads around, then when I got the boxes I was prepared for a loss of quality, but it turned out pretty good. Going to SCART RGB with only one level of switching will be even better!
User avatar
SquallStrife
Postby SquallStrife » 2012-7-14 @ 11:08
Episode 4 is live!
http://www.youtube.com/watch?v=1SbavcrYMcI
I wanted to have my first RGB cable done this week, but without my RGB->YUV converter box, I wouldn't have been able to demonstrate it, so that's on hold for another week.
Today I did a quick unboxing video of my copy of Space Quest 3, including all the sound card related stuff Sierra included, to get you to buy an AdLib or MT-32 off them.
Enjoy!
User avatar
SquallStrife
Next
Return to Release Announcements
Who is online
Users browsing this forum: No registered users and 5 guests
