Spycraft cd issues
First post, by resdog
Hey,
So i'm having issues playing the DOS version of spycraft.
I load up dosbox, type in imgmount w D:\classicgames\spycraft\spycraft_1.iso -t iso
And it shows that it was mounted. I then go to my game directory, which is d:\classicgames\spycraft
Then i type in "spydos" and it starts to load and then gives me an error message about loading disc1
I took a screenshot of the issue.
Any ideas?
thanks.
Reply 1 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Begin fresh and follow the 60 seconds guide. Also read in the readme how to imgmount several images to the same drive letter and switch via ctrl-f4.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 7, by peterferrie
and perhaps mount the drives sequentially - so just C: (hdd) and D: (cd), not C, D, W, X, Y, Z.
Reply 3 of 7, by resdog
Thanks for your help!
I reinstalled everything and set up the .iso files all on one drive. It works perfectly now. 😀
Reply 4 of 7, by IIGS_User
It depends on the game if it supports multiple CD-DROM drives. Later DOS games like Gabriel Knight 2 does,
but that's not the case for usual. There is also a DOSBox limitation, which says,
multiple CD-ROM drives have to be mounted sequentially (D:, E: F:, for example, not D: and F: w/o E: ) .
Klimawandel.
Reply 5 of 7, by wd
Rank DOSBox Author
DOSBox Author
this is no dosbox limitation
Reply 6 of 7, by IIGS_User
DOS limitation. 😉
Klimawandel.
Reply 7 of 7, by wd
Rank DOSBox Author
DOSBox Author
mscdex iirc
