First post, by senrew
Currently, I'm using an older HP machine with a p4 3.2ghz, 1g ram, built-in intel crap video and ac 97 audio on xp sp3. For the most part, this machine runs all of the dos games I've thrown at it pretty well, except for some of the later cpu-intensive or heavy video decoding games. Those stutter and chop like a mofo no matter the cycle settings, etc I've tried. The machine itself isn't as happy as it could be with the single gig of ram just as an xp machine but still.
What would you all suggest as a good baseline for running even the most needy dos games at full speed under dosbox?
Reply 1 of 25, by Gamecollector
More CPU raw power = better results...
The trouble is - the MIPS/GHz ratio of the current CPUs is just 20-30% better then P4... The main targets are - multicore, multimedia extensions (SSE etc) and 64-bit, not the raw power.
The second boost - several cores versus HT or single core CPU - again, just 5-10% of the performance.
So - even with the latest CPUs you still don't have smooth gameplay in demanding areas. Like Vesa/SVGA.
Reply 2 of 25, by senrew
Well then, if that's the case, what are some ways to optimize the DOSbox experience? I tried searching but the search functions on this site hate me for some reason.
Reply 4 of 25, by Gamecollector
I7-i5 MIPS to GHz ratio is around 7.5. Hmm... Well, almost 2 times better then P4 Prescott (3.4) or C2D (4.2), so - even 1.66 GHz i5 is better then P4...
Dunno. The real testing is needed. Cycles=max and then measure the resulting number of the DOSBox cycles.
Reply 5 of 25, by senrew
By chance, would anyone happen to know what the ratio would be for an A8-3500m at 1.5ghz? That's what's in my newest modern laptop.
Reply 6 of 25, by Gamecollector
Well, the easiest way is - run well known Dhrystone benchmark in the vanilla DOSBox. With the cycles=max. Non-optimized versions 1.1 and 2.1 are added to this post.
My result: P4 3.00E, 3 GHz - 36.07 VAXs. 😀
If I run the test in WinXp cmd - the result is 451 VAXs.
Reply 7 of 25, by senrew
Had to find a copy of DOS4GW.EXE to run this it seems. Not sure if it matters, but found v1.97 of it to use from a quick google search.
My results for the A8:
D1:
Microseconds 1 loop: 10.72
Dhrystones / second: 93294
VAX MIPS rating: 53.10
D2:
Microseconds 1 loop: 11.23
Dhrystones / second: 89013
VAX MIPS rating: 50.66
Reply 8 of 25, by Gamecollector
It is P4 or A8 results?
Reply 9 of 25, by senrew
Finally got around to running the benchmark on my p4. It's a 3.06ghz Prescott 519J P4 for reference.
D1:
Microseconds 1 loop: 14.08
Dhrystones / second: 71032
VAX MIPS rating: 40.43
D2:
Microseconds 1 loop: 15.09
Dhrystones / second: 66253
VAX MIPS rating: 37.71
Reply 10 of 25, by robertmo
AMD Phenom 9550 Quad-Core 2,21 GHz
D1:
Microseconds 1 loop: 7.48
Dhrystones / second: 133779
VAX MIPS rating: 76.14
D2:
Microseconds 1 loop: 7.62
Dhrystones / second: 131148
VAX MIPS rating: 74.64
Can anyone test his faster cpu?
Reply 11 of 25, by F2bnp
What games do you want to run that run choppily?
I played through Mechwarrior 2 at 1024x768 on my C2D 6550 (2.33GHz) and it was silky smooth.
Now, I'm on a C2Q Q9450 (OCed at 3.45GHz) and I still can't find anything that slows down on DOSBox 😜
Reply 12 of 25, by Malik
My ASUS G73Jh-1A Notebook (Core i7 720QM - Quad Core, 8 Threads @ Stock 1.6GHz) Results :
Dosbox 0.74 Core=Dynamic, Cycles=20000
D1:
Microseconds 1 Loop : 51.81
Dhrystones / second : 19300
VAX MIPS : 10.98
D2:
Microseconds 1 Loop : 51.19
Dhrystones / second : 19536
VAX MIPS : 11.12
Dosbox 0.74 Core=Dynamic, Cycles=Max
D1:
Microseconds 1 Loop : 7.55
Dhrystones / second : 132505
VAX MIPS : 75.42
D2:
Microseconds 1 Loop : 7.81
Dhrystones / second : 128000
VAX MIPS : 72.85
Dosbox 0.74 Core=Full, Cycles=Max
D1:
Microseconds 1 Loop : 7.94
Dhrystones / second : 125984
VAX MIPS : 71.70
D2:
Microseconds 1 Loop : 7.91
Dhrystones / second : 126482
VAX MIPS : 71.99
EDIT:
Tested the FPS of DOOM :
Dosbox 0.74, Core=Dynamic, Cycles=Max
DOOM v1.2
C:\DOOM>doom -timedemo demo1 [Ent]
Results :
2567 Gametics, 696 Realtics
= (2567 ÷ 696) x 35
= 129fps
Reply 13 of 25, by robertmo
try this one
Re: Pył, Pyl, Dust English language version
Reply 15 of 25, by Kreshna Aryaguna Nurzaman
Malik wrote:
My ASUS G73Jh-1A Notebook (Core i7 720QM - Quad Core, 8 Threads @ Stock 1.6GHz) Results : […]
D1:
VAX MIPS : 10.98
D2:
VAX MIPS : 11.12
D1:
VAX MIPS : 75.42
D2:
VAX MIPS : 72.85
D1:
VAX MIPS : 71.70
D2:
VAX MIPS : 71.99
EDIT:
DOOM v1.2
Results :
= (2567 ÷ 696) x 35
= 129fps
But Doom is a low-res, 320x200 game, bro. What troubles me with DOSBOX is that it is still unable to run hi-res, texture mapped 3D game with adequate speed. My laptop is i5 M520 @2.4 GHz, and when running F-22 Lightning II in DOSBOX, the frame rate is choppy as hell.
Reply 16 of 25, by F2bnp
try this one
Sorry for the late reply, I just saw this, I can't seem to get this to run under DOSBox 0.74.
Whenever I run Pyl.exe it just gives me a black screen. But I did notice that the cycles aren't set to Max, which could be a speed problem.
I played Mechwarrior 2 at 1024x768 at Max cycles. How exactly does DOSBox figure out when to set the cycles to Max?
Reply 17 of 25, by tincup
I've always needed to set Cycles to Max by hand..
Reply 18 of 25, by Gamecollector
With the cycles=auto any protected mode game/app is automatically setting the cycles to max. Theoretically.
Cycles=max - all games/apps are using the maximum (not so good for the realmode games/apps).
About "too slow in 640x480" - 4,8 times more CPU speed is needed for the drawing. So - Doom will be only 129/4.8=29 fps in 640x480 as the example.
For the good (60 fps) 640x480 we need 150 VAX in DOSBox as the minimum.
Reply 19 of 25, by robertmo
you need more memory
memsize=63
