First post, by Shodan486
Hi all
So basically I am trying to clonedisk / imagedisk this machine, due to its highest level of proprietary design - all described in this thread Quite a SCI-FI thing
The problem is I cannot get anything booting besides the floppy drive. I've successfully found and powered up my PCMCIA USB card with a DVD-RW USB connected to it, also managed to use my ''toy'' to connect anything from 2,5 & 3,5 HDDs & Optical devices (SATA and PATA) - all worked in DOS smoothly. But how to get these devices to boot again? Used common DOS drivers like USBCD.SYS / USBASPI.SYS combo, works well. But I need to get them booting (want to boot HIREN's BOOT CD to use some of those HDD cloning / imaging utilities in miniXP).
I've used many locally run programs in the OS, but none of them worked properly as you may find at the end of the above mentioned thread. Tried that g4u as suggested, but that gives me error 79, guess I gotta contact the developers.
Anyways any other boot managing utilities that pop up in your minds? All I wish to do is make a 6GB image of my HDD without extracting the HDD physically. There's GOTTA be a way!
MOBO: PVI-486SP3 Rev 1.2
CPU: POD-83
RAM: 2x16MB
VIDEO: Matrox Millenium 2MB/Voodoo2 12MB/Video Blaster VT300
AUDIO: SB Vibra16 FM
SCSI: 72GB 15k RPM HDD/YAMAHA CD-RW 16x/ZIP drive + FDD drive
NIC: 3Com Etherlink III
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 1 of 12, by Mau1wurf1977
It looks like PCMCIA isn't the way to go in your case.
If you go into the BIOS. What boot options can you choose from?
At the beginning of the linked thread you mention it has SCSI. This is likely the direction I would pursue next.
My YouTube channel
Reply 2 of 12, by Shodan486
not an option, no output. I suppose there has been an extension that might have a classic external SCSI port, but that is just my guess...and ebay has no results upon such a thing.
CPU: POD-83
RAM: 2x16MB
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 3 of 12, by TheMAN
USB boot requires BIOS support, just like ATAPI CD-ROM boot, LS-100, or ZIP drive boot
the best legacy support for external CD-ROM boot is with SCSI, but I doubt there's any PCMCIA SCSI cards that has a built in BIOS, which can supplant the system BIOS in terms of removal disk/disc bootability
this is all too much trouble... it's easier to take the drive out, plug it into a desktop and ghost the drive from there!
Reply 4 of 12, by Shodan486
As ive said, deconstructing and constructing that thing takes half a day, so again, not an option.
Recently I was trying to put DSL on my 486...the boot diskette i downloaded included a USB driver, that was able to boot from my USB PCI card that had an flash drive plus DVD-RW in it, DSL was in the drive and it easily booted from it. So now I cant get the driver to find the PCMCIA USB controller using the Linux floppy, but I know I can get it booting AND now I have a perfectly working DOS environment and no way of getting to boot...shit.
CPU: POD-83
RAM: 2x16MB
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 5 of 12, by TheMAN
PCMCIA behaves differently from PCI... for one thing, you need drivers to initialize the PCMCIA controller before you can do anything with it
Reply 6 of 12, by Shodan486
I thought about that in the first time, but the experience proves the opposite. I can get the DVD RW working, just being hooked up to the card and using USBASPI.SYS plus USBCD.sys. Nothing else.
I know that we have various types of PCMCIA or call it PC Card types, ranging from 1 to 3, being built around both ISA and PCI architectures, details here http://en.wikipedia.org/wiki/PC_Card . There should be some differences between them...
CPU: POD-83
RAM: 2x16MB
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 7 of 12, by lolo799
There is this boot manager wich could be helpful:
http://www.plop.at/en/bootmanagers.html
Quoting some features:
# USB boot without BIOS support (UHCI, OHCI and EHCI)
# CD/DVD boot without BIOS support (IDE)
# PCMCIA CardBus support to enable boot from USB PC-Cards
# Floppy boot
The cdrom version of g4u-2.5 doesn't have the error 79, the latest floppy version that works seems to be the 2.3: http://www.feyrer.de/g4u/g4u-2.3.fs.zip
Give it a try!
Reply 8 of 12, by Shodan486
Well THIS boot manager also promises the very similar as the SBM, though I will try it DEFINITELY. That is exactly what I seek for.
And thanks for the g4u advice, but as long as the booting from any non-nix system, I will stick to that one.
Will report back.
CPU: POD-83
RAM: 2x16MB
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 9 of 12, by lolo799
I haven't tried the PLOP bootmanager or SBM, keep us updated of your results.
I used g4u a few times successfully, it was quite slow on a Pentium 233MHz, backing up a 30GB (3GB full I'd say) drive took the night on the highest compression level.
I recall a local imaging utility for DOS I used on a Compaq IA-1 (some kind of net computer wich can boot from it's internal flash storage or a CF card), it's a shareware called dolly.
Reply 10 of 12, by Shodan486
PLOP is a failure too, though very interesting design 😀. It detects nothing, whether I provide the Socket Services or not, whether I provide my config.sys first, then the PLOP - nothing.
Will try that Dolly.
CPU: POD-83
RAM: 2x16MB
PSU: 230W Generic
OS: Win95 OSR2.5
Reply 11 of 12, by Hatta
Have you considered booting to a Linux floppy like muLinux? If the network is detected, making an image should be as simple as 'cat /dev/sda | nc remotehost port'.
