First post, by Glidos
Well, what the subject says. I've put support in Glidos for running with ISO images for the game CDs
Reply 1 of 6, by maxpen
I encountered a possible glitch regarding dosbox config with this version.
I've pre-installed Dosbox 0.73 and inserted few command lines in [autoexec].
It seems Glidos v1.51 initially tries to load pre-configured dosbox-0.73.conf stored in appdata\local\dosbox folder but it fails to execute Tomb Raider because the config is not properly configured for it.
I had to delete/rename dosbox-0.73.conf to run Tomb Raider and Glidos stores its own config file in appdata\local\dosbox folder, which conflicts with my normal dosbox use.
I'd like to suggest keeping the config file out of appdata/dosbox folder but instead in glidos folder. Thanks a lot.
Reply 2 of 6, by Glidos
Interesting. Glidos doesn't explicitly request the conf file or instruct DOSBox to do so. I guess DOSBox just does that by default. Perhaps I need to add something to the command line to tell DOSBox to use the Glidos-specific conf file.
Reply 3 of 6, by maxpen
Thanks for your reply.
Yes, your assumption was right!
When I execute dosbox.exe in glidos subfolder, it automatically loads appdata\local\dosbox\dosbox-0.73.conf.
looking forward to 1.52 or something 😉
Reply 4 of 6, by Sardoc
Hm... for some weird reason, the link to this special version of DOSBox is no longer in the download section. Is this on purpose?
Reply 5 of 6, by Glidos
Yeah. I simplified things by rolling it into a single download.
Reply 6 of 6, by Glidos
maxpen wrote:
Thanks for your reply. Yes, your assumption was right! When I execute dosbox.exe in glidos subfolder, it automatically loads app […]
1.52 is out and that issue is fixed
