First post, by Guest
Guest
Offline
Will somebody help me? Whenever I press the shift key in DOSBox using Windows 95/98 it puts a 1 on the screen.
Same here ever since before the 0.60 release.
Two stones, two crosses, the rest is just icing. - 7th Guest
get another version of sdl.dll
Water flows down the stream
Dispite the fact that sdl.dll is supplied with every version of dosbox including the cvs versions, and could easily be updated to one with a better sdl.dll file in the next update etc 😒.
you can use any version of sdl you like.
some say the one distributed with 0.58 is very good.
