First post, by Mau1wurf1977
Ages ago I had a thread going about an Acer 486 that I picked up in Perth: Mau1wurf1977's first 486 PC - Lot's of pics - Tell me what I can do with it
At the moment I have a 486DX33 CPU clocked at 25MHz. Now I got quite a few 486 CPUs lying around, ranging from SX and DX CPUs, to DX2, DX4 Intel and AMD and some weird UMC Green CPUs.
I also had three unknown CPUs, unknown because they have an non-removable cooler. I ran some CPUID software and one seems to be a SX, whereas the other two seem to be DX2.
I tried heating up the SX CPU in the machine and then removing the cooler, but in the process chipped off a section, killing it 😒
I don't have a heatgun / hair dryer, but what about baking it in the oven to get the cooler off?
Also. The board has multiplier selections, but no obvious jumpers for 5V / 3V. However there are two voltage regulators and I'm wondering if the jumpers around them select the voltage.
I have a multi-meter, so is it possible to measure the voltage at the CPU socket (without a CPU)?
Looking at the socket, it should be a socket 3 (237 pins, no I didn't count them but found socket images on Wikipedia showing the difference between socket 2 and 3).
Is it possible that the board can detects what CPU it is and set the correct voltage?
My YouTube channel
Reply 1 of 3, by Mau1wurf1977
It's alive
So it turns out the socket is indeed a socket 3. But I couldn't find any voltage jumpers, though after some more searching on the net, there is indeed a way of auto setting the voltage for certain boards.
I came accross some old threads on VOGONS (seriously what ISN'T on VOGONS), which linked to this fantastic resource:
http://web.inter.nl.net/hcc/J.Steunebrink/amd5x86.htm
It shows a simple test for checking if the board auto sets the voltage. And it does! 😀
I tested with VOLDET grounded and floating and the Voltage did indeed change from 3.44V to 5.01V confirming that I can use these lower voltage CPUs in my Acer.
So I inserted an AMD 133 and although the POST screen thinks it's a DX-2 (I believe the 2x multi is 4x with the AMD), the CHKCPU utility identifies it as a DX4 with the correct clock speed.
I set the FSB to 25MHz and later to 33MHz and ran some tests and took pictures. I haven't got a cooler that fits, just one for Pentium sized coolers, so I just placed it loosely on-top.
One thing about this machine: It has no L2 cache (mainboard cache). The sockets are all empty. So keep this in mind regarding the benchmark results. Not sure how much of an impact it has...
My YouTube channel
Reply 3 of 3, by Elia1995
I have a 486DX4-T100 which gets detected as a DX2 in my Socket 3 Olivetti M4 434S, strange isn't it ? 🤣
Currently assembled vintage computers I own: 11
Most important ones:
A "modded" Olivetti M4 434 S (currently broken).
An Epson El Plus 386DX running MS-DOS 6.22 (currently broken).
Celeron Coppermine 1.10GHz on an M754LMRTP motherboard
