First post, by hifidelitygaming
There's no single appropriate board for this and no way to squeeze everything into the title...
If I want to capture highest quality lossless video on frequencies which are NOT some standard NTSC or PAL resolution and not modern HDTV, any recommendations on how one would even do such a thing? For instance anything over 60hz (like the 70hz common in earlier PC games from direct X 5 up) or CGA, or EGA, or Hercules, or doulbed NTSC/PAL modes from amiga, or 70hz 640x400 atari ST, or those 76hz Macintosh modes from around the Mac 2 era... how would one go about capturing this stuff at high quality?
Assume that emulation is not an option, and I don't desire to transcode to 60hz before ripping if I can help it. Things like PC demos or early games on various systems are the main target. How would you do it?
