First post, by F2bnp
Hello, I just got an Audigy 2 ZS recently and I wanted to install it on a fast Tualatin system and possibly do a dual boot setup. However I can't find any drivers for Win98SE for this card. It seems as if only WDM drivers are available and these are for WinME and up.
Can I use those on Win98SE?
Creative's website does not have any Win98SE drivers btw, I already checked.
Reply 2 of 6, by F2bnp
Yep, I can only find the Audigy Driver Disc, apparently this is Audigy 1, I have no idea if the drivers will work with my card. I have no experience with the Audigy cards, I just happened to find an Audigy 2 ZS at a good price 😜
Reply 5 of 6, by F2bnp
Yeah, I downloaded the Audigy 2 ZS driver disk and there is a folder named VxD, so it probably has Win98SE drivers. I'll try it and give you a heads up.
Reply 6 of 6, by swaaye
I'd like somebody to hack together a way to install the VXD drivers without using the CD at all. It takes so long to run the CD install, and then you need to reboot a few more times to switch from WDM to VXD.
