First post, by dirkmirk
I'm in the process of building a P3 Tualatin 1.4ghz and are comtemplating what type/size of memory to use, I scavenged an old box and found a 256meg Kingmax PC-150 module, a quick search on ebay gave 0 search results, did this type of memory come out when DDR was starting out or something? I assumed this stuff would be easy to find.
AND
Is it worth tracking down PC-150 modules to overclock compared to cheapy PC-133 ram sticks? Would the Tualatin chip overclock higher with PC-150 or not much difference? My mainboard supports 1mhz increments from 133-166mhz fsb.
