First post, by lafguy
I have games off a 3.5 floppy I load into dosbox. I was wondering is there any way I can copy the installed files in dosbox to a cd? My next system won't have a floppy drive. I highly doubt a usb floppy would read a dos game floppy.
Reply 1 of 7, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
1. use the latest and greatest Dosbox (0.72 is really really old already)
2. USB Floppy drives work fine
3. use Winimage to make a disk image of your floppies and use imgmount in Dosbox to mount your diskimages. If your game needs multiple floppies, use SVN of Dosbox (or next version after Dosbox 0.74 when it comes out).
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 2 of 7, by lafguy
Ok got that to work but, now I can't get full screen.
fullscreen=false
fulldouble=false
fullresolution=2560x1440
windowresolution=original
output=surface
autolock=true
sensitivity=100
waitonerror=true
priority=higher,normal
mapperfile=mapper.txt
usescancodes=true
Monitor: Eizo Coloredge CG275W
If I run dosbox 072 like above I get a small screen to the left works fine.
If I put fullscreen=true
I get same small dosbox screen more in the middle with just the words no border and a red retangular square on top.
I have bought some GOG games that go full screen just fine on this monitor
7th guest 11th hour etc
Any ideas
Reply 3 of 7, by Dominus
DOSBox Moderator
sorry for the strong language but when one ignores the very first part of the first answer, I can't help myself...
DON'T FUCKING RUN 0.72. IT'S ANCIENT!!!!
You might have to do other things besides upgrading AND READING THE MANUAL (of 0.74 that is), but I won't help until you did that (<- UPGRADED TO DOSBOX 0.74 AND READ THE MANUAL).
Reply 4 of 7, by lafguy
Sweet response TY.
I went to 074 it worked fine. I just need to learn how to keep mount so I don't have to type it each time I open dosbox.
Reply 6 of 7, by lafguy
Thanks for your help. I'll set the dosbox later. What are your favorite games on dosbox?
Reply 7 of 7, by IIGS_User
Or: "What games are (or was) available for DOS?"
MJVGA by Ron Bajewski
Mah Jongg by Nels Anderson, runs in Hercules mode as well.
Klimawandel.
