First post, by Mannard
This drag racing game by Bethesda was almost identical to Burnout: Championship Drag Racing..
I mounted up the directory and ran SETSOUND (successfully)
Ran NIRA.exe and the game showed the Title Screen and then crashed
displaying this message:
A Fatal Error Occured:
Problem Allocation Memory while reading file: SOUND\LAMV12M2.WAV
Your efforts are appreciated.
Thanks,
Mannard
(System Info: i5-430, 4GB DDR3, Window 7 64-bit, Intel HD graphics)
SYS64738
Reply 1 of 6, by Davros
what do you mean "mounted up the directory"
Reply 2 of 6, by Mannard
😳 Umm..
C:> Mount C C:\NIRA
SYS64738
Reply 3 of 6, by SKARDAVNELNATE
Mannard wrote:
😳 Umm..
C:> Mount C C:\NIRA
Could you be more specific? Normally directories aren't mounted for Windows games.
Reply 4 of 6, by Davros
Exactly drag racing is a 1999 game so it should be a windows game
why are you trying to mount the game folder for a windows game
and what program are you using to mount it the mount looks like a dosbox command but you arnt using dosbox because
1: You would of mentioned it.....
2: you posted in the windows forum not the dos or dosbox forum
3: you dont use dosbox for windows games
Reply 5 of 6, by eL_PuSHeR
[Merging topics trying to fix your mess]
[Thread moved to DOSBox Games/Apps. Section for now]
Reply 6 of 6, by ripsaw8080
Rank DOSBox Author
DOSBox Author
Sounds like it's a DOS version, because otherwise you'd have seen a message about running the executable in Windows. Considering the error message, and that it's a 1999 game, I suggest you try increasing memsize (max is memsize=63) in the conf.
