Reply 40 of 49, by SavantStrike
sliderider wrote:
If your Dell has a proprietary power supply, you will need one of these to make the switch to a standard ATX. […]
jmrydholm wrote:
Oh it's ok. The Optiplex only has a single V2 in it. My XP machine with a bigger, better PSU holds the SLI rig. I have a desktop from 2003, the old Dell, and my Alienware m11x. I probably shouldn't buy any more computers for a while 🤣
http://www.endpcnoise.com/cgi-bin/e/std/sku=dellconverter
You'll probably find hacks for converting an ATX PSU to Dell, but using this adapter is a lot easier and you can still use the PSU with standard ATX boards later without having to reverse the hack.
The only thing that bothers me is it's not clear if Dell ever used a non standard pinout on the 20 pin ATX connector, but omitted the extra AT style plug. Then there's no identifiable way of knowing if it's standard or not without further research.
Reply 41 of 49, by sunaiac
would those work : http://www.ebay.fr/itm/4x-16MB-64MB-30pin-SIM … =item2326b5fba8 ?
Regards;
R9 3900X/X470 Taichi/32GB 3600CL15/5700XT AE/Marantz PM7005
i7 980X/R9 290X/X-Fi titanium | FX-57/X1950XTX/Audigy 2ZS
Athlon 1000T Slot A/GeForce 3/AWE64G | K5 PR 200/ET6000/AWE32
Ppro 200 1M/Voodoo 3 2000/AWE 32 | iDX4 100/S3 864 VLB/SB16
Reply 43 of 49, by sunaiac
thx 😀
Reply 44 of 49, by sliderider
I own 3 Dell Optiplex GX1 PII/PIII machines and trust me, the pinout is different.
Reply 45 of 49, by JackH
Have anyone outside from The USA (especially from Europe) order those ram from https://eshop.macsales.com/item/Other%20World … uting/30PS16MB/ here? Trusted place? 5.15$ International Mail + taxes(outside EU) Delivery & Paypal?
I would use them with my SB32 CT3600.
BTW any reason why most 16MB 30pin's are sold in The USA? I Can't find them in Europe, not even Ebay? Were they rare back in the day, expensive or they came time when 72pin's already taking over, etc?
Reply 47 of 49, by tayyare
This is exactly where I buy 30pin and 72pin SIMMs, when I can't find reliable secondhand options. I purchased SIMMs from them at least 4 times in the past, and there were no problems whatsoever.
GA-6VTXE PIII 1.4+512MB
Geforce4 Ti 4200 64MB
Diamond Monster 3D 12MB SLI
SB AWE64 PNP+32MB
Adaptec AHA29160
3com 3C905B-TX
Gotek+CF Reader
Reply 48 of 49, by zatara
Sorry to bump this topic, but soes anyone know if these modules would be compatible?
https://www.ebay.com/itm/115027555306?hash=it … v4AAOSwVMBhWves
Specs:
4MB modules
OKI M5117400F-60 FPM (fast page mode)
Organization: 2 chips of 4x 4Mb density
Non-parity (8-bit)
30-pin SIMM
5V power supply
Low latency of 60ns
2k refresh cycle
Low profile of 13.5 mm (0.5")
I'd have two pros buying these modules:
1 - The are purple! Super eye catching =]
2 - Free shipping makes it cheaper for me to buy this 4-piece set than it would be to buy a pair of usual green modules.
Thanks in advance guys!
Reply 49 of 49, by pc-sound-legacy
Hi zatara, they will work fine on your AWE32.
