New Gaming Rig, need advice.
Reply 20 of 29, by Mau1wurf1977
I don't have Windows on this machine. It's a simple FORMAT C: /S from a W98SE boot CD 😀
I made a video, it's in the Time-Machine Playlist. Installing MS-DOS 7.1 or something like that.
My YouTube channel
Reply 21 of 29, by Pingaloka
I decided to install Windows 95 at the end.
Which version do you guys recommend?
Reply 23 of 29, by Pingaloka
So Windows 95C would also be ok Mauwurf1997?
Also no need to install Ms-Dos right?
Just format c:, boot from a floppy disc with cd-rom support and install Win95 right?
Reply 25 of 29, by Pingaloka
Mau1wurf1977 wrote:
Nothing is ever that easy 😀
W95C? Hmm ok now I'm confused 😁 Maybe someone else can help.
Yes, as far as I'm concerned there's Windows 95C, which obviously came after Windows 95B
Reply 26 of 29, by senrew
http://en.wikipedia.org/wiki/Windows_95#Editions
If you scroll down a bit there's a table with specifics.
Halcyon: PC Chips M525, P100, 64MB, Millenium 1, Voodoo1, AWE64, DVD, Win95B
Reply 27 of 29, by Pingaloka
So, I'm a bit lost with Windows 95.
Am I supposed to install any drivers?
I'm using a Yamaha YMF719 for sound, I know I need drivers for this one.
An S3 Trio64v+ 2mb card which is detected. I set the monitor to a 640x480 res and no problem. 1024x768 and no problem. But I try 800x600 and image doesn't appear centered.
DO I have to choose monitor? Or just Plug-n-Play?
Also if I want to use VESA/SVGA do I have to install a Vesa fix just like in MS-DOS?
Reply 29 of 29, by northernosprey02
Yes if you want using PS/2 mouse, otherwise go to serial port mouse. The bracket has USB port so you can using USB port on your computer. But if you using W95B, you need install USB Supplemental Driver to make USB working in W95B. Otherwise, go to W98 if you want native and complete USB support. Correct me if I wrong 😀
