Opengl prob?
First post, by Raven
I have a problem with Dosbox 0.61 and those cvs versions that have the opengl options.
If I try to use dosbox with opengl in fullscreen the screen becomes blank and the power indicator on the screen twinkles.
If I run dosbox in a window, dosbox runs ok.
Is this a problem of dosbox or is it something I have to change in my settings?
my system is a
p4 1800
512mb ram
geforce 4 ti 4200
sound blaster live
Reply 1 of 8, by CobraA1
Sounds like your monitor doesn't suooport the resolution/refresh rate DosBox is trying to set. I've noticed that XP will sometimes allow modes that the monitor doesn't really support, even when "Hide modes that this monitor cannot display" is checked in the advanced display properties!
Try this:
set fullheight and fullwidth to your current resolution, and set fullfixed to true.
Reply 2 of 8, by Guest
Thanks it almost worked.
I did the things you suggested and I can see the screen now.
But if I start a game, I get a field around dosbox that shows the desktop.
[edit: do NOT POST LINKS TO BITMAPS]
Reply 3 of 8, by CobraA1
Try setting fullscreen to true.
Reply 4 of 8, by Raven
That didn't work.
With fullscreen true, dosbox don't work at all it just returns to windows.
Reply 5 of 8, by Jackal331
fullscreen=true
fulldouble=false
fullfixed=true
output=opengl
fullwidth=1152
fullheight=864
hwscale=1.00
autolock=true
sensitivity=100
waitonerror=true
_______________
p4 2.6
sapphire radeon 9200 64ddr
As first i must say : Thanks for new dosbox !!! Continue with good work ! And as a second i have to say, that i have a little problem: i cant switch to opengl, when i do, the dosbox do a fullscreen and the its black screen for 3 seconds and then it crashes. Any helpfull recommendations ?
And another question, what overlay option means ? And what hwscale means ? Which options i have to use for best results 1.00 - 10.00 ... ? Thanks for advices.
Reply 6 of 8, by MiniMax
Rank Moderator
Moderator
For me, the 'overlay' function allowed me to view a game on my TV in full-TV mode, while still running it in a windows on my TFT screen 😎
I have to say, that the colors and everything looks *so* much better on the TV than on the TFT screen.
MiniMax
_________________
Reply 7 of 8, by Raven
I have the same settings and problem as Jackal.
If I chose fullscreen false, my first problem returns.
Reply 8 of 8, by eL_PuSHeR
I think someone has already posted about this. It seems DOSBox kicks you to desktop if OpenGL full-screen is invoked at startup but works properly if started windowed and then switched via ALT-ENTER. Weird.
