First post, by silsor
For some reason the VGA emulation doesn't work properly for the old Nahlakh RPG. I posted details on this at http://dosbox.sourceforge.net/comp_list.php?showID=1888 . Does anybody have an idea why text stays on the screen after it's supposed to be cleared or why the colours get all messed up? Maybe it's a mode switching improperly?
Reply 1 of 12, by jal
Have you tried to adjust the "machine" parameter in the config file? the "auto" setting doesn't always work correctly. Try setting it to "vga" or"cga". Some games (notably older Sierra AGI games) autodetect Tandy, but then go ahead using EGA, causing similar problems.
JAL
Reply 2 of 12, by silsor
Changing the machine option doesn't help. With VGA the game has the same graphics errors, and with CGA it correctly refuses to run (it's a VGA game). Other than these graphics errors the game seems to run perfectly.
I took some screenshots:
This is the opening screen. It works fine. The game cycles the palette during this screen to create the illusion of shifting red clouds.
This is the load game screen that appears next. As you can see the palette has been reset to the standard VGA 256-colour palette but the intro screen has not been erased.
This is the in-game screen. Nothing has been erased yet, everything is being drawn on top.
This is a character's inventory. It too is drawn on top of everything else.
Edit: I also tried it with CVS dosbox, same problem.
Reply 4 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
do those messages in the debug screen happen at the same time or at moment the screen should be emptied ?
if you scroll a window enough the window get's empty. Might be some behaviour this game is relying on...
Water flows down the stream
Reply 5 of 12, by silsor
The error messages happen at the same time the screen should be blanking. I can't tell if there are the same number of errors as there are lines on the screen, because there seems to be no way to scroll up in the debugger.
Reply 6 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
ah okay This is the problem:
I think it uses the scroll functions to clear the screen
We didn't implement scrolling in VGA as nobody seemed to use it.
Oh well here's one that uses it 😀
Reply 7 of 12, by silsor
Seems like a pretty silly way to clear the screen. Can I hope for a fix for this sometime? I'm not stalking you, I just happened to be fixing the screenshots at the same time you replied ;)
Reply 8 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
maybe/probably.
But as only one games seems to use it at the moment it isn't given a very high priority.
Using scrolling the clear the screen is quite common in text mode though. for VGA it's indeed a bit strange.
Reply 9 of 12, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
Not just one ...
There is probably similar problem in those Ultima 2 and 3 VGA updates:
ultima 2 and 3
141133809: INT10:Unhandled mode 6 for scroll
Mirek
Reply 10 of 12, by Qbix
Rank DOSBox Author
DOSBox Author
hmm it's not that hard to implement.
Oh well let's see if I can find those games.
Reply 11 of 12, by silsor
The scrolling problem is fixed now in CVS, thank you for writing that function. There is one minor graphics issue left:
In this screenshot the text should be visible, but the skill names seem to be printed on a background of the same colour. The ratings look mostly okay, I don't have access to real DOS right now so I can't tell if the ones with the background colours are supposed to have them.
Reply 12 of 12, by Harekiet
Rank DOSBox Author
DOSBox Author
Hmm yes annoying, was kinda wondering when this was gonna happen since in mode 0x13 you can't xor characters on the screen using bit 7, but bit 7 is just part of the color 😀
Edit:
Okay that fixed now too i think.
    1.84 KiB
    yeeha
