First post, by StefSOFT
Hello guys and girls,
I'm trying to make a simple shell script which runs a dosbox instance and a custom configuration file.
The script currently looks like this:
#!/bin/bash
BASEDIR="$( dirname "$0" )"
cd "$BASEDIR"
open -a DOSBox --args -conf conf/preferences.conf
When running the script DOSBox opens, but still uses the preference file from ~/Library/Preferences/DOSBox 0.74 Preferences.
The last command in the script I got from this wiki page: http://www.dosbox.com/wiki/DOSBox_and_Mac_OS_X
The .conf file is a copy of the original preference file, with full screen changed to 'true' and some custom autoexec commands.
Anybody knows what I'm doing wrong?
Goal of this exercise is to make dosbox run with all the contents in it's own folder, so I can create multiple folders for different games and run them with a simple double click in OS X.
Reply 1 of 8, by IIGS_User
-conf /Path/to/your/Configuration_file
Klimawandel.
Reply 2 of 8, by StefSOFT
So in the dosbox folder I have a folder named "conf" and in there a preferences.conf file.
Reply 3 of 8, by StefSOFT
Ok, this command is working:
DOSBox.app/Contents/MacOS/dosbox -conf conf/preferences.conf
Reply 4 of 8, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Damn my answer got lost ;(
I wanted to point out http://www.dosbox.com/wiki/Mac_OSX_Advanced which has my AppleScript for doing that nicely 😉
You have your special configs in one folder and yo choose via doubleclick in the AppleScript GUI.
But your problem might be solved by entering the full path to the conf. Since you are starting from an App bundle relative paths get confused at times (hence why your other solution works)
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 5 of 8, by StefSOFT
The goal indeed was to make it relative to only the game/dosbox folder. In that folder I created the start.command shell script, I'm able to run the relative conf file and mount the relative c-drive and cue file. Everything is now working as expected. Thanks for the link though, I will read into that.
Reply 6 of 8, by mr_space
Just a quick message for Dominus, thanks for the script! I use DosBox on a 2004 eMac, not having DBGL running in the background gives me free "power". I had to add a "/" somewhere , I also add a line to hide the .map files in the launcher.
Reply 7 of 8, by Dominus
DOSBox Moderator
💪 glad it helps and you got it working!
I‘m still using it all the time but don‘t know anymore if I needed to change things.
Reply 8 of 8, by mr_space
Worked out of the box on my 2008 iMac, maybe a bad copy/paste on the eMac. Yes, I've just checked the original script, thanks again! Next goal, a PPC version of openxcom... ^
