First post, by brandsizzle
Hey Guys, I'm pretty new to the Retro Gaming scene but I've been able to collect a large amount of items for next to nothing in my city. I'm having an issue with the Roland SC-55 MKII that I got and just wanted to confirm the behavior I'm expecting is correct and that the Mini-Headphone jack is broken.
I have a Awe64 card with a game port to midi cable, from this using the midi out port (330) I'm able to send signals to the SC-55 and games like Doom show they are playing the music and Windows 95 is able to send songs as well.
My issue is that no music ever comes through the headphone jack, if I use RCA output to headphone stereo plug in the Awe64 line-in I can hear it but it's extremely low.
Should the SC-55 Mini-Headphone jack always output music? Does it matter if the Midi 1 and Midi 2 input is used? What about the slider on the back (should it be set to midi?RS232C.1 or .2)
The RCA Outputs are working but I assume are not amplified and as expected the sound is very low. I am using a small set of speakers that aren't powered while testing these machines.
Reply 1 of 14, by keropi
since I only have a MK1 I can't tell you about the headphone jack for sure but:
- the slider switch should be set to MIDI
- doesn't matter if MIDI 1 or 2 is used, I would stick to MIDI 1 just to be on the safe side
- the RCA output is line-out level, it needs amplification
Reply 3 of 14, by Great Hierophant
If you are using the 5-pin MIDI port, then the switch is supposed to be set to MIDI. If you are using the 8-pin mini-DIN port with a serial cable, then the switch is set to RS232C-1 for 31.5kbps and RS232C-2 for 38.4kbps. RS422C is for the Macintosh. If you connect the SC-55mkII with a gameport/MIDI cable, you should have the switch set to MIDI. The MIDI cable should be connected to the MIDI IN on the back of the unit.
Reply 4 of 14, by brandsizzle
Thanks for the info, looking at it again I'm pretty sure the headphone port is broken (the volume seems fine as it does affect the slight volume out of the RCA output) but it also seems to have other issues.
While testing every so often when playing the built-in midi songs the unit would power cycle, now when using a USB to Midi adapter (cheap one off DealExtreme) and in Dosbox outputting via Midi it just restarts the unit over and over but you can see it accepting the signal for a short second before doing so.
I'll just have to track down an amplifier as that has always been in the picture and hope it stays solid through the gameport to midi cable, at the same time keep an eye out for another unit and look to sell this one as is (sad though as it is in mint condition with original adapter and manual)
Now I just have to find a way to determine if my Roland SMPU/AT ISA Card works and if it's worth tracking down a breakout box for it. Thanks Guys
Reply 5 of 14, by brandsizzle
So after testing with an amp the output is still extremely low, after opening it up and inspecting the board I found the large 2200uf 16V capacitor has leaked. I will purchase a new one and replace it and continue testing.
Not sure if anyone see's any value in me documenting the teardown process or the repair.
Reply 7 of 14, by brandsizzle
Hmmm, I could be wrong I guess... though there is no other glue on the main board. I've replaced quite a few caps from older video consoles and that looks pretty consistent with what I've seen. This issue with this unit are quite numerous
Headphone jack doesn't work
RCA Output sound is extremely low even when connected to amp or not
Device randomly and occasionally power cycles over and over
I'll replace it anyways and see if that makes effects anything, I may just replace all the caps as I've seen that do miracles for older electronics. If that isn't it this thing will be nice for parts if I can find a working SC-55 MKII that may be banged up.
Reply 8 of 14, by keropi
That's glue 101% , if that amount was acid leakage the sc-55 board would be a mess ... look here: Have you opened your SC-55 to check the battery inside?
If you are unlucky and the unit is indeed damaged (could be the onboard ICs , you never know...) please don't throw it away , as you can see on my sig I am looking for a mk2 housing/display/ports 😉
Reply 9 of 14, by brandsizzle
If it is glue then the 2200uf cap is the only surface mounted capacitor on the board, perhaps someone can take a pic and we can see if this is normal. It's also possible with the flash the picture I took just doesn't give the correct detail, but the brown's and mustard colours as what I'm used to seeing in blown caps (though normally from the top)
I will agree that with a flat top and no bulging you are almost winning me over. Don't worry I won't toss it, I'd just give it to anyone who wants it. Once I'm done build a couple of my machines I will take dozens of extra video and sounds cards, plus processors and P1 mobo's that I'll just dump off to retro enthusiasts.
I've uploaded another pic of some other caps (and various wiring) to show the rest of the board looks clean of glue
Reply 10 of 14, by keropi
basically this is the only cap on the mobo that has that glue... my mobo also has it, your has it and even Stefan_L's one has it:
http://www.ym2149.com/roland/roland_sc55_pcb_partside.jpg
it's there on this cap because it's the biggest one on the mobo, can't really tell you how that affected assembly so they used glue 😀 but it's normal
kudos on your decision to offer stuff to people 😊
edit:
here's a pic of one of my MK1s , you can see the glue as well
or a CM-32L:
maybe the roland people liked the smell of glue back then 🤣 🤣 🤣
Reply 11 of 14, by brandsizzle
The evidence just keeps mounting, the second pic does show some of the brown and dis-colouring that I assumed by electrolyte. I'll look around for any issues with the PCB and swap out the capacitor if need be. Thanks for all the info keropi, I appreciate it.
Reply 13 of 14, by brandsizzle
So I got around to looking at this, Keropi you were correct that the capacitor looked good even after removing but appeared a little loose. I replaced it anyways and found 2 cracked solder connections which appeared to be grounds under the 3 midi ports. I fix that with some extra solder and tada, the sound is fine and the headphone jack works. Likely the last user put a lot of strain on the midi ports with his cables, a good thing to note if you have a headphone jack issue with this system.
