Pentium 166MMX Box Performance problems
First post, by nemail
Hi all!
I've recently started to build some old gaming rigs for various old, cool games and after successfully reviving a 386SX, 486DX2-66 and P2-266 I'm encountering Problems with my P1 166MMX box.
Specs are:
FIC PT-2007 Board most recent BIOS
Intel P1 166MMX (the new, black one)
Voodoo 3 2000 PCI 16MB
256MB SD RAM
YAMAHA OPL3-SAx ISA Soundcard
Realtek RTL8029 PCI NIC
Iomega ZIP 250 ATAPI
Some CD-RW drive
As mentioned earlier I'm having Problems with this box, Performance Problems to be exact.
Games like Diablo 2 with LOD Expansion are stuttering, also GTA (Windows Version) runs veeery slow. DOS Version runs excellent, but without Sound (didn't dig into that issue, probably no dos Sound Drivers).
Sub Culture runs quite OK.
First I tried Sub Culture with my Hercules Stingray 128/3D with 4MB Video ram - no Chance. got it running only in Software or Direct3D mode and it was very slow too.
Years ago I had a Compaq Presario 4162 with a Pentium 150MHz without MMX (overclocked to 166) and I used to use the very same Voodoo 3 2000 PCI Card in that box and I can remember that that PC was capable of running games like NFS Porsche unleashed like a charm, as well as many other games from that era. I can remember that I didn't have to upgrade my Hardware for a very Long time thanks to that Voodoo 3 Card.
I've installed the most recent Intel INF Update as well as the inofficial Windows 98SE Service pack 2 and some modded 3dfx Drivers called Omega (most recent Version i could find).
I've also installed DirectX 9.0c.
I suspect that the IDE Controller maybe the Performance bottleneck, it seems to not Support UDMA, in the BIOS Settings I can only choose between PIO modes 0-5, but in Windows I've selected the "DMA" Checkbox in the device Manager (and it doesn't get deselected after reboot).
Does anyone have an idea what could be the Problem here? As far as I've read the PT-2007 board was quite fast back then...
Thanks,
nemail
Reply 1 of 21, by Davros
get hdtune
http://www.hdtune.com/
run a benchmark and post a screenshot
Reply 2 of 21, by d1stortion
The 430TX chipset can't cache anything more than 64 MB RAM. In DOS having more than this may not be a big problem (I doubt many DOS applications are even going to use that amount), but in Windows you may well end up with bad performance due to how it fills RAM. Try running only 64 MB.
Besides, your PC doesn't meet the minimal requirements for Diablo II, so I'm not sure why you are even expecting good performance here.
Reply 3 of 21, by nemail
Davros wrote:
get hdtune
unfortunately hdtune doesn't work on Win98SE 🙁 do you know any other tool?
edit: i found aida64 to have some Benchmark Tools included. I'll post the results below.
Thanks, I'll try to get smaller Memory modules somewhere. as a first step I could only reduce to one module (128MB).. 🙁
I'm quite sure that Diablo 2 worked very well on my old P1 150MHz Box years ago, thanks to the mighty Voodoo 3 Card 😀 But thanks for that hint anyway, I didn't check the sysrequirements of Diablo 2.
Reply 4 of 21, by nemail
CPU usage is not correct, process Explorer and also the Windows integrated System Monitor state about 20-30% constant load (from the Moment Aida64 is started, even without benchmarking).
edit: Windows integrated System Monitor says also 100% coninuous cpu load. process Explorer says 20-30%. weird...
This however consumes very much CPU power, almost 100% cpu load all the time.
Reply 5 of 21, by Davros
I'd say your certainly in pio mode
your board supports udma/33
does it have dma drivers (a lot of boards around that time needed them)
you said in the bios you can choose between pio modes is there an auto setting ?
Reply 6 of 21, by nemail
i've spent the last few hours searching Intel storage Drivers which will probably enable dma, but i could only find Intel inf update Utility (which installed fine).
also the "dma" Checkbox stays enabled in the properties of the hard disk after a reboot and it also makes a difference wether it is enabled or not. if it's disabled, i only get about 8mb/s in the first benchmark...
Reply 7 of 21, by F2bnp
To enable DMA just download the Intel INF and then go to the Device Manager on your Control Panel, find the Disk Controllers and enable DMA on them. It should work 😀.
Much like d1stortion said, the 430TX can only cache up to 64MB and installing any more than that will make the system feel sluggish. Try to find a 64MB DIMM, even 128MB will be a problem for the system!
Also, while GTA should have been running perfectly fine, Diablo II will certainly have a hard time on the MMX.
You could try using higher multipliers to get this MMX to 200MHz or even 233MHz. MMX 166s are usually binned 200 or 233 chips, so they should work just fine at those frequencies and will give you a small boost.
Reply 9 of 21, by nemail
news:
-installed Drivers referred by davros
-installed one 32mb sd ram module
-checked bios (again) for udma Settings, set pio mode to Auto on all drives
bios shows during boot for my hard disk:
PIO Mode 4, UDMA Mode 2
Aida 64 says: supported UDMA Mode: 5, current running UDMA Mode: 2
DMA Checkbox still stays ticked after reboot, which indicates that dma should be enabled
still gta is veeery slow in Windows mode (in dos mode fast as hell) and Benchmark results are the same, and also cpu load stays at 100% during Benchmark.
should i really try the steps "remove/reinstall ide Controller" and so on like mentioned in davros's link?
is it possible that this seagate 60gb drive doesn't Support udma33 anymore? there's nothing else connected to that ide channel, disk connected to the end of the cable and set to master.
the bios only recognizes 8gb of the disk, can that be the reason? it didn't bother me much because 8gb is quite enough and i assume that there is a bios Limitation which i can't get around anyway (except ddo which i don't like much).
also i have an ISA soundcard in that System, can this be the reason? I'm not sure but sometimes it feels like GTA is getting slower when playing many Sound effects...
edit: turned off ingame Sound and Music, GTA still slow...
Reply 10 of 21, by d1stortion
I'd trash all unofficial "service packs"/drivers. Something like this released in recent times is meant for people still running these old OS for web browsing etc. on newer PCs, not a vintage system like yours.
Reply 11 of 21, by nemail
reinstalled on another 40GB Seagate IDE hard disk using Seagate Diskwizard booted from floppy disks.
plain win98se from cd + Omega 3dfx Drivers + DirectX 9.0c + inf update Utility, enabled dma mode -> same Problems 🙁
do you think it could be the unofficial Omega Driver? People were using that one earlier without any issues...
Reply 12 of 21, by tincup
You can always try original 3dfx and reference drivers - here's a site that hosts a variety:
http://www.falconfly.de/voodoo3.htm
I've had good luck with the Unofficial SPs, though I usually only install the Basic Updates and Performance Tweaks, and the IE Core stuff which is sometimes needed for the Supplements/Desktop updates to work.
Reply 13 of 21, by F2bnp
Yeah, go with reference and why use DX9c? I wouldn't use anything newer than DirectX 7.0 on V1/V2/V3.
Reply 14 of 21, by nemail
Hi
tried now with reference Drivers and DirectX 7, although I already had 9.0c installed and simply overwrote it with 7.0 (what may cause issues 😁) by changing the Version variable in the registry.
Still the same, GTA 1 in Windows mode unplayable.
-3Dmark 99 gives about 1000 3dmark Points and all Benchmarks run around 10fps at Default Settings. I can't remember exactly but I think that this box should perform way better
-dxdiag says that DirectDraw and Direct3D works fine, the tests there are running smoothly.
@Tincup:
I was about 10 years old when I had my own Win98SE box and by far I didn't have the knowledge I have now - and I've forgotten many things too. May I ask you to list some of your Basic updates and Performance tweaks, IE core stuff, and so on? I'll then document that and implement it on my future Win 98 installations 😀
However - I see 4 possibilities here what might be Happening with my P1 box:
- I'm too stupid to setup Win98 the right way on contemporary Hardware
- The Mainboard, and/or chipset and/or Drivers are crap
- I'm blinded by the Performance of recent machines and everything i saw is perfectly normal
- some Kind of defective Hardware is causing the issues
Reply 15 of 21, by d1stortion
Could well be that the Windows version of GTA is just a bad port. Try Forsaken, where you should get over 60 FPS or Turok (demo has a built-in benchmark).
Reply 16 of 21, by nemail
ok will try that asap, thx!
Reply 17 of 21, by tincup
I was referring to the Service Pack component options - I only select a few:
Critical Updates
IE6 Core [I find this is needed to enable some desktop/graphic features, tho I'm strictly offline]
Performance Tweaks
I seem to get equal results with SP 2 or 3.
Beyond that I install W98se with as few of the optional components as possible , then:
Visual Basic 6 runtimes
nusb33 [it should be in the SP but if I get USB issues I reapply it]
DirectX 9.0c [I like it, it's very reverse compatible, and it's always seemed the most stable of the W98se supported Dx releases - the last in fact]
Motherboard chipset drivers
Audio drivers
Video Drivers
Then usefull system apps like 7zip, MagicDisk/DaemonTools, Acrobat 5, CPUz & GPUz, etc.
That's about it..
Have you checked Device Manager for any ! entries? Maybe your drives are operating in Compatibility mode or there is some resource conflict.
I think you should fresh install at this point as you may be getting orphaned driver/dll conflicts from all the fussing..
Reply 18 of 21, by nemail
tincup wrote:
I was referring to the Service Pack component options - I only select a few: Critical Updates IE6 Core [I find this is needed […]
Critical Updates
Performance Tweaks
ah i see.. i'm using the Windows 98SE Update Pack 2.1d (German) from here:
http://winfuture.de/downloadvorschalt,1350.html,d.Yms
can't remember any IE6 option there... which SP are you using?
tincup wrote:
Beyond that I install W98se with as few of the optional components as possible , then: Visual Basic 6 nusb33 [it should be in th […]
Visual Basic 6
you talking about the full VB6 IDE or just the runtimes?
nusb33 is a mass storage Driver or....?
DirectX 9.0c: f2bnp told me not to use anything newer than DX7 with my Voodoo Card... I forgot everything about installing DirectX so i was not sure whether DirectX was backward compatible or not...
tincup wrote:
Motherboard chipset drivers Audio drivers Video Drivers Then usefull system apps like 7zip, MagicDisk/DaemonTools, Acrobat 5, C […]
Audio drivers
Video Drivers
sure Thing...
tincup wrote:
That's about it.. Have you checked Device Manager for any ! entries? Maybe your drives are operating in Compatibility mode or t […]
That's about it..
yeah, no yellow exclamation marks, no compatibility warnings, everything seems to work perfect, except the fact that the System feels way slower than it should be according to my memories.
Didn't test that Forsaken/Turok thing yet, though.
What I've done yesterday is reinstall everything from scratch on another hard disk, didn't work the way it should either...
I've also tested NFS Porsche Unleashed which should work with a P1 200MHz and a 4MB graphics card. It worked with about 12fps, I've expected more, due to the Voodoo 3 card and I'm also not sure if I have played that on my P1 150MHz years ago or if it already was my K6-2/400...
Reply 19 of 21, by tincup
VB6 - yes, just the runtimes - under 2mb. Some apps/games need it so I pop it in.
DirectX can't really be over-installed with a older version. If you want to go back, best to start fresh. That said I use 90c with my W98se.
Your system *should* feel snappy on the desktop. Opening closing panels and menus should be sharp. Is the system lagging on just the normal stuff?
NFS Porsche system requirements list a P200mmx as the minimum CPU required, so you know what that means haha... probably really needs a P450+ for full res-good FPS, and crappy performance on a 1997 P200 era rig...
