cdoublejj wrote:... since it runs so cool any ways the top mounted fans work pretty well not even powered/hooked up to any thing. 🤣 I plan on getting a fan to put in there and spin at low RPM or just leave the grill in there (no fan), and mount a front 5.25 bay fan (no top fan).
If you keep that top front fan, at least flip it to make it work as intake. Otherwise being upwind from the CPU it will just rob cool air from it.
With that top front fan as intake, and another 5.25 intake fan, you'd get great CPU cooling.
cdoublejj wrote:... remember heat rises... if there is any.
Convection only has a (minimal) effect in totally passive systems.
As soon as there is a single fan in the case stirring the air you can kiss goodbye to any convection.
Vertical vs. Horizontal Case Cooling
"... Convection should (in theory) aid in cooling with a system running in a vertical orientation. However, our measurements do not support that theory ... ... Our conclusion is that the forces of convection in a computer are simply not strong enough to overcome even the turbulence and airflow eddies caused by the fans ...
... Convection, while a strong concept in thought, simply does not generate the results necessary to play a discernible role in a typical chassis ..."
