First post, by simonkay
Hi
Using DOSBox 0.74-1 on Mac OS X 10.9.4 64bit.
I type in the following commands:
Z:\>mount c /tmp/blah
Z:\>copy nul c:\blah.txt
And my DOSBox hangs.
On my Windows 7 x64 box, running DOSBox 0.74:
Z:\>mount c c:\dos
Z>\>copy nul c:\blah.txt
And it hangs here too. So it doesn't appear to be platform-specific.
I take it this is a bug. Is it a known bug? Where should I report it?
(Running real MS-DOS 6.22 under VirtualBox, COPY NUL filename results in "0 files copied", and the file is not created. So, it would be DOS-compatible for DOSBox to have an error here. But hanging is a bit too much.)
It's not stopping me from doing anything, but someone should fix it anyway.
Thanks
Simon
