First post, by Soupdragon
Does anyone know how I can get this port of doom to output music to my sc-55. With dosbox I can change the device to not be the built in software synth but with this I cant see an option. Windows 7 doesn't seem to have an option to let me change midi device to my usb to midi adapter.
Please move this if its in the wrong section I wasn't sure as the game is a port.
Steam | World of Warcraft
Reply 2 of 5, by Soupdragon
Cheers 😀
Reply 3 of 5, by Soupdragon
MMaximus wrote:
There's a utility called "Putzlowitsch's Vista MIDI Mapper Control Panel" that works in Win7 and allows you to change the midi output device
http://sierrahelp.com/Utilities/SoundUtilitie … IDI_Mapper.html
I cant get this to work I drop the .cpl file into the windows\system32 folder but I cant see it in control panel
Reply 4 of 5, by Soupdragon
Never mind I found with 64 bit windows I had to put the file into windows\syswow64 folder now it works.
Reply 5 of 5, by SquallStrife
Well duh, use one that isn't made of chocolate.
