NFS Porsche problem
First post, by eFatal2ty
Hi everyone, I have this problem with the game NFS 5 Porsche Unleashed:
On GeForce2 Ti 64MB i have a very low fps in this game aproximately 16-20fps, even at 800x600 low
I am using 30.82 nvidia driver, i have tried others also (29.x and 45.x versions) - the problem persists
Even Voodoo 2 SLI is running at full better than this 40fps+
Other DX7 games runs perfectly 1280x1024x32Bit Very High 60FPS+
is there some solution or patch for Geforce 2+ cards?
Thanks a lot.
*ASUS P3B-F *Intel Pentium!!! 450MHz Katmai@133fsb *Hynix 4x128MB SDR PC133 CL2 *Matrox G400MAX 32MB + Procomp Voodoo2 12MB SLi *Creative SB Live! CT4760 *3Com 3C905C-TX-M *2xSeagate 40GB 7200rpmn *EIZO T68 19"CRT * Creative FPS1000 *OS: MS Win 98SE
Reply 2 of 21, by eFatal2ty
Yes of course, and another thing: In Video menu I dont have option to set up higher 32bit, than 1024x768, 16Bit is up to 2048 x 1536
Reply 3 of 21, by Living
same here with k6-2 500 + Voodoo 3 2000.
i remember back in 2000 i had a K6-2 500 with Aopen PA3000 32MB (TNT2 M64) and it ran just fine even in 1024 x 768...
Reply 4 of 21, by eFatal2ty
There was a hack to setup 1024x768 resolution on V2SLI also run fine on other Voodoos to run game in Glide - try it. 😀
1.Open 3dsetup.ini and rewrite it by this:
under your card change line CARD_3dfx Voodoo 3 /M:dx /I to CARD_3dfx Voodoo 3 /M:voodoo2 /I
Run 3DSetup.exe again and choose your 3dfx voodoo card then check:
2.windows registry key
HKEY_LOCAL_MACHINE\SOFTWARE\Electronic Arts\Need for Speed - Porsche Unleashed and it should looks like that, if not rewrite it by this:
Entries:
Group: "Glide"
Trash driver: "Voodoo2"
Works just great with my Voodoo 3 3000AGP! 😊
Reply 5 of 21, by filipetolhuizen
Is Triple Buffer checked? About the resolutions, if you have a lot available, the game is able to show only a limited number.
Reply 6 of 21, by eFatal2ty
Yes it is, i have tried on/off it. -nothing changed.. How can i unblock the number?
Reply 7 of 21, by Davros
try my 3dsetup it goes higher
    3dsetup.zip
    134.02 KiB
    217 downloads
Reply 8 of 21, by eFatal2ty
Its the same. My opinion is that if i wouldnt had all the resolutions available nothing changes... like on the voodoos sli
Reply 9 of 21, by GL1zdA
Did this patch 6 years ago but it seems it is still floating on the Internet (have somehow lost it since then).
I have also done a LOD bias patch which corrected LOD on >2 GHz machines, but since there were so many versions of the game I've distributed it only as a manual patch (how to patch bytes at a specific offset). If you need the offsets you should decipher it from here: http://glizda.wordpress.com/2009/10/05/need-f … -cpu-lod-patch/ .
    PU32bVMp.zip
    58.51 KiB
    199 downloads
    Need for Speed: Porsche Unleashed 32-bit modes only patch
getquake.gif | InfoWorld/PC Magazine Indices
Reply 10 of 21, by Gamecollector
IIRC there is the ACT fix (HideDisplayModes) for the same purpose.
Reply 11 of 21, by eFatal2ty
I found this: http://www.racerplanet.com/forum/showthread.php?t=17766 , itfix the resolutions, but no performance gain at all
Reply 12 of 21, by GL1zdA
Good, somebody did a nice package with both fixes. Unfortunately I have never experienced the performance problems so I can't help you further. I've played Porsche on a GeForce with a PIII 700 back in these days,and it worked well.
Reply 14 of 21, by Davros
you you explain that sounds usefull I would like to hide resolutions for some games
Reply 15 of 21, by filipetolhuizen
This will also hide all widescreen resolutions. If your screen is wide, this is not useful.
Reply 16 of 21, by Gamecollector
Unpack the attached file and run this command: sdbinst -q NFS5.sdb
It installs HideDisplayModes and EmulateHeap ACT fixes for porsche.exe and porsche.icd.
Sdb files are created/edited by MS Application Compatibility Toolkit (ACT). So - google this program and tutorials for it.
If the game needs this ACT fix - it was developed w/o widescreen support. 4:3 only.
    NFS5.7z
    499 Bytes
    176 downloads
Reply 17 of 21, by Davros
You cant choose what resolutions to hide ?
Reply 18 of 21, by b_rros
I tried in my K6-2 400 with a GeForce 256 DDR, using the same drivers, 30.82, and it's slow to, even at 640x480, using the SLI voodoos it's the same (but looks way worse)...
I can remember playing this back in the day with almost the same setup, at the time I had a slot1 pentium 2 500 instead of the K6-2.
Reply 19 of 21, by filipetolhuizen
No, it automatically hides all 16:9 and 16:10 modes. According to ACT, it's the default Win9x behaviour.
