Reply 20 of 23, by sergm
Eek. If so, I'll add that option asap 😀
Hmm, SF is in trouble by now as I can see, posting here so you NewRisingSun can test it.
Works great so far. Thank-you for doing this merely because I asked. 😀
Another question: the DOSBox patch no longer allows the maximum number of partials to be set (option mt32.partials). I readded it myself, and find it working nicely. Any particular reason why this was removed?
Eek2. Thanks for pointing this out, I'll fix it. Probably it was lost after I mixed the release/svn patch code together 😒
EDIT:
Ah, you probably mean mt32.partials option found in Ykhwong's builds. I think it was never there in the patches I've dealt with.
