Problem with Descent
First post, by Guest
I managed to get Descent working (mounted the drives, etc) and set up a profile with DFend. I then went and upped the cycles to speed the game up, and all of a sudden the text file Descent expects to find is no longer there (The one listing available memory, etc), and it will not run. Has anyone found a solution to this problem?
