First post, by Dos Game Player
Here is a idea for some more DOSBox commands:
(with their syntax)
unmount {dosbox drive letter} {real drive letter}:\ -t {type)
This will unmount the drive you enter whitch is handy as I sometimes mount the wrong drives
lconfig {mounted path}
Loads the config file of your choice, restarts DOSBox and loads it with that one. You can also put a /d switch at the end to make it the default DOSBox config.
If you could put it in that would be great! 😀
